nah they arent that bright really, and what makes you think it was nighttime??? :D
you know how the camera never lies? well, it does. a lot! lol
I got myself a little GoPro camera a month or two back and just bought the suction mount. So will have to try this out with a little basic camera.
Cheers
Andy
i bought myself a Nikon D700 and a 24-70mm F2.8 Lens :D there is no way in hell im putting MY camera on a mount. That said, my mate put $10K of Nikon equipment on the suction on my car hahaha
i bought myself a Nikon D700 and a 24-70mm F2.8 Lens ;) there is no way in hell im putting MY camera on a mount. That said, my mate put $10K of Nikon equipment on the suction on my car hahaha
I agree, I have the D70s and there is no way that is going out there, thus the GoPro.
Tried it on the bike and in the surf on the w/end and it was great.
Nice shots, Brendo! Are they enhanced, or straight off the camera? I think I'm getting used to seeing that huge chunk taken out of the bottom of your DAYZ bar where the intercooler is, as well.
cheers, was a friends canon eos50d, 1st of the 3 photos is remarstered, the other 2 are 3-shot exposures laid over into 1 frame
but.....
the engine is farked. either piston ring or oil pump, thought it was turbo oil seal but its not turbo related; got to check it out a bit more & see whats going on (ie compression tester kit needed)
post-49463-1240718070_thumb.jpgpost-49463-1240718139_thumb.jpg[a
ttachment=219470:Stagea_wreck.jpg]Here are some photos of my recently departed S1. I will post up my new one when I have installed the chipped ecu and have a dyno chart to go with it.
First is at Taupo with the v35 wheels and road tyres.
Second is at Manfield with R32GTR rims and Bridgestone semi-slicks.
Third is after i have salvaged all the bits to put in my new car.
and to you too, LOVE the 32
might as well post pics of your new stag in here, close enough to owning it and it's super sexy :(
:bunny:
just wait a few days and i'll post up some pics of my own when i get it :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
