Now I got her some new shoes heres my girl -
just got to get her out of the clouds a bit.....
that ride height doesn't look too bad
get a dayz front bar and it will look even better :D (will look exactly like mine)
pic of the stag now she is coming along just got to wire emanage ultimate in, got it friday and injectors and tune all else done well for this stage any way :thumbsup:
Edited by 4bidn1
Looking great guys :cheers: Whose doing your emanage tune?
mine were about $89 trade from sprints cant remember brand but they are adr approved. no probs at all except if the control box gets too hot like on a 40 degree day like today with the box mounted in engine bay they turn off so if i relocate box into cabin no probs, had them about 3 months will find out brand for you
4bidn1, any info on your LED DRL's??
i've had hit and miss experience with the cheap ebay ones, not sure i want to fork out on the super expensive hella dayline's...
I've posted these up in a seperate thread before but thought I may as well put them here aswell.
Wheels aren't mine, 18x9.5 +18 all round, I think I need 19" instead. (GT-Cs or something along those lines)
Nice pics man. I like the clear indicators on the front. The rear of your car is different to mine, as I have different brake and indicator lights and a chrome piece at the end of the brake lights either side of the number plates.
I will throw some pics up of mine sometime today to show ya :thumbsup:
sounds like you have series 2 lights
here is my stagea and my other toy, the old and the new, the fast and the slow. my tastes couldn't be further apart.
hey man, I'm gonna be up around the 10th-13th of feb, should catch up and go for a cruise or somethin :)
And anyone else in Adelaide who's interested? :)
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
