My M35. Pretty happy with how it looks. Perfect stance for me. Even at this height, I struggle with my low hanging Kakimoto exhaust. Next on the list - dump & front pipe.. deciding whether to go a mid muffler or hi-flow cat.. any suggestions..?
Very nice!:thumbsup: That is a really nice package with the 350Z rims; colour, ride height, all spot on.
The Aero looks so nice in Gold; almost as nice as Black...:whistling:
I'm still torn; not really sure about the Aero skirts on my Black; they look so good on the light colours, but on black they just look heavy.
Maybe I need to get hold of some PM skirts; more pumped than the stock ones, but less than the Aero.
Hmmm, might need to perve on Alex's at the Stag Anniversary...:ph34r:
I'm with Cam; a dump & mid pipe with a high flow cat will really wake it up. Exhaust volume won't really change; but you do get a nice burble once the restriction is gone.:whistling:
Edited by Daleo
I think the aero kit is just perfect for the M35.. i wasnt keen on the gold before the purchase, now i love it..
Not too sure about the PM skirts, but personally i wouldnt go any other kit besides the aero.
was for the exhaust, the reason i wanted to go a mid muffler was main for the flow, im not too concerned on the sounds side of things..
thanks for the input guys!
Mind you, when Jetwreck was under my car, all I heard was "mmmm, thats different, thats different , thats different"!!!
There seems to be more and more they changed S1 to S2.
Have to check it out Sunday. Hope we get some good weather.
Couple of photos of Longroof.
Fake RS260 bar on an RS4S
Giant sideskirts kinda dont suit the rear...
Failed rego inspection specifcation R32 skinny rim tuck for lols.
Was so embarassed to be sitting in my car in line behind a 996 GT3 and a newish Jag XKR at the inspectors with tiny R32 rims about a foot inside the guards.
The jag failed.
interstate cars may require a local inspection before rego is given.......
Yeah, I realise. I was just curious as to why the car might have failed the inspection.
Just picked up my Stagea from the autotrans depot this morning. Bought it in SA.
I'll have to take it to the pits to get a WA rego soon; not looking forward to that part.
Will post a pic when possible, maybe later today :D
not too sure,they are 18s but they are going cos they have bad gutter rash from the last owners.ill be getting 20s in the same style if i can find them,
Looks nice and clean. What wheels are they?
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
