Oh My! Well Then I need to stop being so poor!! :P I didn't know they were that costly in Australia!! Even more respect to you guys for working so hard!!
If you think thats costly, you should see what we have to pay for a big american pick up. Well in excess of 100K for an F250 that costs less then 30k over there.
I miss living there and the cost of cars and even more so performance car parts
Everything is relative in each different country, not judging your own financial situation.
Welcome to the forum, it will be interesting to see whether more Stageas make it to the USA given the changes to import regs.
Yea absolutely!! I'm really hoping we will see more, I would love to get my hands on one!! Thanks for the welcome!! I really appreciate it!! I'm hoping they will become a bit less uptight with the emissions requirements
Ànd we would kill for the pricing you guys get on you're cars!
Luxo cars often cost double if not more in Aust compared to the US.
I know I'd jump into a E55/63 wagon if I was over there!
Yea those are nice!! They are rare here too!! :) I would send you guys cars at our prices if I could!!
MY GOD!!! I can't believe that!! I can't imagine how hard you guys have to work!! So much respect!!!
  • 1 month later...
  • 1 month later...
Wow, the blue looks really good.
My mate took the pic of my missus black wags and its inspired me to get my old camera out for a crack.
Its a old point and shoot thats about 15yrs old now.
Just a pic in the driveway 2nite.
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
