hey guys ive tried searching couldn't find wat i was looking for
just wondering what fuel economy you guys get out of your r33
i dont get the best, around about 250kms>$65 bp ultimate around town
10psi
cooler
exhaust
walbro pump
5spd
could anyone else tell me if this is normal or bad?
https://www.sau.com.au/forums/topic/125582-r33-fuel-economy/
My factory stock R33 SII 4dr auto gives me an average fuel consumption of about 11.6 l/100km which is about 430km on a 50l fill up.
Any idea how that will change when I fit a 3" catback and K&N panel filter?
usually fill up around the 1/4 mark, bp ultimate, 3"exh, pod, FMIC and on 7-8psi, getting 300k, also depends on driving. Mostly m4
Just had a major service, installed exh cam gear and EBC so will see how it goes now!
Do all R33's have fuel lights? Never had mine come on but have had it near the line!
the light will turn on for about 5 seconds then turn off when you get in the middle of the line then it will come back on and stay on when you have about 10 litres left i think.
You get plenty of notice on a r33 (so im told) ive done 30 ks when the light came on and turned off again
maybe i will test it, i have never seen it come one when i have run pretty low, but then again the fuel goes down and comes back up a bit again, not 100% accurate!
10psi
cooler
exhaust
walbro pump
5spd
I get about the same. Around town, havent really been pushing it. 5spd manual, similar mods: cooler, pod, exhaust, 11.5 psi
$70 ultimate got me 270kms last time round :\ gonna get it tuned so it doesn't run as rich, then we'll see if it improves.
ah you have plenty of time even when the light goes on... you can get a fair way down under the 'E' line as well... its only when you turn a corner, get on the gas and it misses and splutters that you need to fill up LOL
Ah come on dude. You didnt even have to search, dont tell fibs :nyaanyaa:
Its all in the sticky thread (Forced Induction Guide)
Here are some links for you to have a read over
Guide itself:
http://www.skylinesaustralia.com/forums/in...showtopic=66556
And related links from the guide:
http://www.skylinesaustralia.com/forums/in...showtopic=43095
http://www.skylinesaustralia.com/forums/in...?showtopic=2879
Cheers :rofl:
R33 - pod - 3inch exhaust - plumb back bov.
I only got 380kms out of 50litres, and 200kms of that was 5th gear freeway kms.
I'm looking at about 250-300kms per 50litres city driving.
I drive it easy, jump on boost quite often, standard skyline behaviour.
Changed my O2 sensor last week. Has made no difference at all.
The way I see it, you want performance, it's gonna chew up fuel.
On the other hand, my mate's FPV F6 turbo goes through a tank every few days. Now that's crazy.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
