Any graph to view? The outright power figure is very impressive for the boost you've run.
How are you finding the 56T / VG30 combination in terms of streetability and response with the 2.4 litre capacity?
  • Replies 121
i will get a graph once i get the tune checked over, i havent got one printed since the headgasket was changed. but had a quick look at the run he did and it had 12psi by ~100kph in 4th.
actually it feels really good, mind you i havent really tested it properly as i'm abit unsure how healthy the tune is, but the rb25 housing felt better in regards to response but had surging and boost spiking issues.
but SR20s spool turbos better than rb20s due to their longer stroke
what is the compressor and turbine A/R on the hks GTRS?
currently im really keen on the GT2871R highflow cos it all bolts up, and from what i hear, the exhaust A/R is 0.63
HKS unit has comp .60A/R, turbine .63A/R.
A carefully thought out high flow can work very well, but the apparent aims of factory engineering needs to be factored in when using factory-spec housings.
In some respects I'm not massively surprised that kwazza11 had troubles with surge with the 56T comp and 2.4 litre capacity. My calcs for the RB25 suggested it would be borderline, depending on the power target. Using the VG30 turbine housing is a way of masking a technical mismatch and still getting a satisfactory overall performance characteristic. If the compressor is not excited as easily due to the higher flowing turbine, then it will not be pumping as much air at the middling engine revs, giving a marginally lazier transient response but eliminating surge - and also giving excellent high end power. I actually think it was a clever and practical way of making the turbo mate well - just not how I would have/did do it.
If you are insistent on doing a Garrett GT2871R cartridge type high flow into RB20, depending on your exact objective then go either 48 or 52T comp, and use the RB20/25 turbine housing. If you can get some piping mods sorted, use the Garrett 0.60 A/R comp housing and have something close to a GT-RS. Just remember the more fabricating you have to do, then the financial advantages of going with this decision start to diminish.
cheers
Edited by Dale FZ1
Not really on topic but dale fz1 you sound like you know a fair bit about turbos, can you recommend any good reading, books articles etc for learning about flow maps, how to match compressors to a/rs to motors etc?
i agree dale, the 56t matched to the rb20/25 housing is definately on the edge. would be even worse on the stock bottom end, i actually order the 52t 2871r in the first place but the workshop i purchased it from sold me a 56t telling me it was the 52t, when i questioned him about it he said he hadnt realised and offered to chase up the proper comp but called me back 2 days later saying it would take him 2-3 weeks to get the wheel in. was sick of his BS by then so i ended up just keeping the 56t.
the turbo works really well, just make sure you have the wastegate bored out as much as possible if using any of the nissan housings.
Not really on topic but can you recommend any good reading, books articles etc for learning about flow maps, how to match compressors to a/rs to motors etc?
We'll stick on-topic here, but try
www.turbobygarrett.com and read their tutorials; they are very, very good and easy to follow
Turbochargers by Hugh MacInnes (if you can find a copy, will be in specialist bookshops).
I have another text that was published early 90s and still on loan to my mate.
cheers
its internal gated
have always had boost issues, previously, boost always dropped off, now spikes. Changed controllers no diff.
Its all good though, car doesnt ping and knock levels do not go over 20
h.
That you have knock apparently well controlled is a good thing.
I wouldn't be at all happy with the boost skyrocketing at the top end of the rpm range - recipe for a hand grenade under the right (read: wrong) conditions.
So your 2871R is fitted to an SR20, uses a .63 A/R turbine housing? It's a stock, off-the-shelf Garrett unit fitted to a fairly stock engine and manifolds?
What was changed that you went from boost falling away to boost running away?
Main point of interest is if there are any lessons to learn in fitting a similar spec unit to an RB20.
cheers
Hi boost at top end is not an issue, as i dont take it past 7000rpm. As you can see from the dyno. Hi boost is an issue down low, as thats when rods can break. Up top you'l only damage rings (so i have been told).
There 2 things that we are assuming which is the problem to why boost sky rockets
1. I have re-ground exh cam with ajd cam gear - that may need adjusting. Have set it to 0 and just fitted cam. If i play with the timing it may stop the boost spike and give me a fatter mid range.
2. Wastegate hole needs to be machined
I wont be doing anything for now as im happy.
cheers
i agree with Dale in that the ideal combo for a RB20DET would be a 48T GT2871R with a RB25 exhaust housing. this would allow the turbo to easily mate with the standard manifold and dump pipe if required.
the 56T comp wheel is just too big for the 76T turbine where it is able to flow enough air for ~475hp, whereas the 76T's efficient limit seems to be ~400hp. Also, i believe the 52T is probably as big as you'd like to go on the GT2871R although be it with an A/R .86 exhuast housing for ease of flow and increased efficiency.
if you look at the garrett website (www.turbobygarrett.com), you will see that the efficiency of the 76T turbine actually decreases as you go bigger in compressor wheel.
anyway, just my 2c, feel free to put me in my place if you feel you need to :)
  • 1 month later...
I have just purchased a HKS GT2530 upgrade kit from nengun Japan for my R32-RB20DET as my stock turbo shredded all the turbine blades like potato chips last week. I have been doing tons of research into which is the best and most practical turbo upgrade for the RB20 with T3 flange and I have decided to go with the 2530.
I have a long way to go and alot of mods to complete the project. I will keep you updated on how the installation goes and on final dyno results.
There are so many paths to take when upgrading the RB20 turbo. I hope my experience will help some of you to make the choice that is right for you.
Rgds, Grippy :P
Rgds, Grippy :laugh:
Yeah well I'm in the same boat too but I ordered the HKS GTRS. It should be here sometime this week from nengun. Could be a few weeks yet till I can install it but it should be a well worth the wait.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
