  • Replies 40
Posted Images
Not good.
Looks like plaster though, so damage can't be 'too' bad......
How does the car look after all the crap was taken off?
While its only gyprock, the garage ceiling is a bit over 4 metres so it had a lot further to fall than a normal ceiling.
Damage is scratches on every panel (some could be buffed, some too deep) and some nasty dents on the roof and read quarter panel. Might be some other small dents as well, but I havent taken it out and cleaned the dust of yet.
https://www.sau.com.au/forums/topic/127221-noooooooooo/#findComment-2349714
