  • Replies 280
Posted Images
Haha yeah a skyline view, it's meant to be ideal for weddings. Sounds rather $$$$ to me. Especially since you need 30 peop for the small skyline room. Will check it out maybe just the same. The earl seems to be getting a strong following at the moment though.
Man did I plan this a month from now?? I could have planned it a fornight away if progress keeps happening this fast!
I think what I'll do once there's a number of suggestions up that people like, is post up all the options with internet links if possible (& menu listings if really required) & then people can PM me with their votes. The location with the most votes wins.
Keep it up guys this is gonna be great :P
Edited by Electro
Keep it up guys this is gonna be great :happy:
I'm not serious re the Skyline Restuarant, just thought this was the perfect thread to highlight the fact that Adelaide actually has a Skyline Restuarant.... ;)
trust me nozila u almost need your stomach pumped its GREAT value for 15bux
So does one have to own a Skyline to attend a Skyliner's social? hehe..
i think you allready know the awnser to this but just in case no... no you dont... but u non skyline drivers pick up the tab :P
Edited by Madaz
Freebaggin - Yeah I was kinda doubtfull about it, to say the least :D
Busky2k - You're more than welcome to come. Just expect to be treated as an outcast :no:.
Naah seriously though, all are welcome, Drew doesn't even have the right brand anymore :D
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
