Again nothing too, but the ones either side, ...507 and ...509 are Vspec 2 NUR versions and manufactured in May 2002. So odds on ..508 is same.
Wow, you got the B3 CD... where did u get it?
Anyway, thanx alot, now I'm sure it's the genuine NUR spec. Thanks... hihi
Was this ever expanded upon? My car has one of those odd model codes.
KBNR32RXFSLMZG
Strangely this gives a build date of 6/90 rather than the FAST 10/89 for my chassis BNR32002505:
http://fteqw.com/moodles/model-decoder.php...amp;chassis_no=
This doesn't give all the answers either. So weird. :)
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Figured as much, that was a 'best guess' on chassis number. I'd be interested to find out WTF Nissan was doing with the model codes. :)
Ok i found out the full VIN.
Im looking at buying these cars..
If you could please let me know if these cars are series 2, and any extras etc..
1st: ECR33110049
2nd: ECR33133148
Greatly appreciated!!
1st one's options are
Super fine hard coat
Audioless (left factory without stereo ?)
passenger airbag
ABS
2nd one only has ABS as an option
Hi can you help with an advertised White 1994 R32 GTR V Spec which I want to check whether it really is a V Spec?
VIN 6U9000BNR32314072
thanks Mike
its not V-spec
Hi,
I've got two more to check please:
BNR34003174 - Vspec
and
bnr34404299 - Vspec II
not coming up on mine, sorry.
Thanks for this great service, I cant believe how many people advertise V Spec when they are not.
Another one advertised as a V Spec I, in Melbourne
VIN BNR32312504
Mod No KBNR32RXF72AA
Silver, Built 09 - 1994
It doesnt sound like it is as I have heard if there is an X in the Model No it is not a V Spec. It wouldnt be a V Spec I in 1994 either would it?
Can you please check for me asap
thanks Mike Perth
VIN BNR32312504
thanks Mike Perth
Doesn't appear to be a V Spec...
Trying to find out of my gearbox has a push or pull type clutch..
It probably is a dumb question but im running out of options trying to figure out if my new clutch will go in or not, f**k r34 N/A's and their assortment of parts
Hopefully fast will tell me. It worked for my diff :)
er34010972
Thanks
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
