I need to find a part for this model number - BGKBRTFR33VDA-A--- (not sure if those dash's are needed) the car is a ECR33 gts25t 4 door
the part i'm after is the plastic tube which goes from the heater core out into the firewall (not sure if you type "heater core pipe" if anything will come up)
maybe this picture might help
if anyone can help that would be greatly appreciated :D
Hi, me again.
I haven't bothered to install FAST so I'd like to find out a chassis.
BCNR33042544 - Supposedly 10/97 in dark blue series 3 (not sure how to tell if it's series 3 on FAST).
Thanks again
Grant
Mat,
My friend downloaded the software for me (I'm no good at torrent stuff).
If i can have it copied or my friend who downloaded it have them in his hard drive I could give you a copy if possible?
Cheers
Grant
LotusGTR: BNR32 304958
Model:KBNR32RBFSAA
Series:R32
Produced: 07/93
Ext Colour: KH2
Int Colour: G
2K
RB26DETT
HI.4WD
GT-R.17
MT.F5
_______________________________________________
HairyMerkin: ER34004904
Model:GGKAREFR34EDACKFCB
Series:R34
Produced: 06/98
Ext Colour: KV2
Int Colour: G
2K
RB25DE
IRS.2WD
25GT
MT.F5
Angela22: ECR33022544
Model:GGKBRTFR33VDAA----
Series:R33
Produced: 12/93
Ext Colour: 1N3
Int Colour: K
2K
RB25DET
HICAS.2WD
GTS25T/M
MT.F5
69GTT: BNR34000437
Model:GGJPRVYR34ZDAAAJ-D
Series:R34
Produced: 01/99
Ext Colour: GV1
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F6
Jensilein: BNR34002455
Model:GGJPRWYR34ZZAABKED
Series:R34
Produced: 03/99
Ext Colour: LV4
Int Colour: G
2K
RB26DETT
HI.4WD
GTR/V
MT.F6
Squareznboxez: ER34012270
Model:GGKAREAR34EZAACF-B
Series:R34
Produced: 07/98
Ext Colour: GV1
Int Colour: G
2K
RB25DE
IRS.2WD
25GT
AT.F4
Count Grant: BCNR33042544
Model:GGJPRWFR33ZZAAAQ-C
Series:R33
Produced: 10/97
Ext Colour: BN6
Int Colour: K
2K
RB26DETT
HICAS
4WD
GTR/V
MT.F5
I think people have better things to do than upload 1gb of software!
Well clearly those 'better things' DO NOT include fasting VINs for fellow SAU members thats for sure.
Thanks, Ruffels, any chance you could do the VIN I posted up a page back? Thanks.
For those that are whinging and whining you can very easily find the software yourself!
It is not rocket science to use google and search for it, but for the people that are missing a chromosome i will provide a link where you can get it yourself so you can stop asking people to do it for you.
NISSAN FAST SOFTWARE
Read the first post for install information.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
