October 1989
thankyou very much for that..
ive been looking around on the forum but cant seem to find what MZG mean the last three letters of the model number...
ive figured out everything untilll L which is foglights but MZG has got me thinking...
if anyone knows would be great..
Cheers
According to wikipedia, the series 2 33s started in 1996 and yours is confirmed a 96 model. The series 2 also have driver and passenger air bags, do you have them?
Thanks mate.
It has dual airbags which I understood to be an option too. I thought the fogs might be blanks and it was a transplanted front bar (but then I found the switch and they work :P ).
It looks like the s2 centre console - from what I can tell the s1 and s2 have slightly different shapes - could be wrong there though.
Also has factory sunroof but I understand this is also an option on s1 and s2. I'm guessing the build date should put it into the s2 lineup but I have heard about these s1/s2 hybrids.
Anyway thanks for looking, I was just more curious really. Everything seems to work though, so all good.
QUOTE (Owgasm @ 8 Oct 2010, 08:49 AM)
Still looking for some info:
If anyone else can give it a go:
BCNR33-000102
Thanks in advance
Can't find that one.
Ah, again.
Any ideas why my cars not showing up? Anyone out there?
Ah, again.
some cars just dont show up. given that any copy of nissan fast distributed outside nissan motor co is strictly illegal, we are lucky to be able to use it to any extent at all, so we dont complain when it doesnt seem to have a record of a few vehicles. i'm in the same boat as you, my R32 supposedly doesnt exist either.
alternatively you can post up the model code instead and fast can decipher that, it will tell us everything except production date, exterior colour and interior colour. put that up and i'm sure one of us will be happy to oblige
Awesome thanks for that :(
So my 32 was made in jan 1990, colour is metallic black rb20det type m. in manual
whats 2k and HI.2WD mean?
2k means coupe i think and HI.2WD means HICAS (rear wheel steering) and rear wheel drive.
Can you fast this vin for me it's of an 200sx 6u900000515020397
It's apparently an Autech whats the easiest way of telling?
I was about to say that I don't know how to tell if its an Autech, but then this came up:
So yes its an Autech.
Hi,
Could you please verify this VIN?
BNR34-003026.
Thanks!
PMed.
Edited by Dark26
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
