That's where I got the HNR number. It's also stamped into the firewall. So it should be the correct one.
Anyway, Aug 89 sounds good. I'm going to have to put it on club reg - just can't afford increased rego fees just announced fir Vic.
Yeah should be, as long as they Blue Plate and the VIN stamped on the fire wall match, then all is good.
But yeah, AUG 1989 sounds about right for you car.
  • 3 weeks later...
JN15 400465 - need to know if it's an Autech asap :)
Spare parts for Nissan Pulsar with JN15 frame, 09.1997 - 10.1999 manufacture period
Frame / Series JN15 / N15 body 3HB (3-door hatchback )
engine SR16VE (1600 VVL gasoline )
drive 2WD.PUL (2 wheel drive Pulsar )
Production month 10.1997
grade N1
transmission MT (manual transmission )
Interior color G
Body color KH3
http://nissan.epc-data.com/pulsar/jn15/3511-sr16ve/?frame_no=Jn15-400465
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
