Maybe it was a Statesman mule - it was Left Hand Drive after all - so it didn't have Holden insignia or name badge.
But trust me - it had a HUGE rear end.
Most likely. Many LWB models will go to middle East, China (even longer than Australia's with more chrome etc) and Korea.
M-E mainly use statesman, they are also LHD.
  • Replies 109
wink very nice pic....thanks.
Where did you get it? Should be a couple more days till the unveiling :(.
Anyway thanks.
Got it off the Motoring section of http://forums.overclockers.com.au/
(You'll need to register to view those forums)
Come on, can't be all bad.. Half the country owns one, they don't look too terrible (agressive even) and they can clock up many hundreds of thousands of km, often never serviced, can be upgraded for more power fairly easily.. and they do have a high power-weight ratio compared to most other cars out there. The new ones don't even chew that much fuel for their size.
If we didn't have commodores I don't know what else everybody would be driving. Large oversized, overfueled and overpriced 4WD ? Korean cars. 10+ year old japanese imports? camrys? magnas?
They serve a useful purpose, and even though I'm not a huge aussie car fan, I have some respect for what they do given circumstance.
Chris Rogers my experiences with the VE have been different. I’ve recently compared the panel gaps with the new Camry and IMO the gaps seems to be smaller on the new commodore (especially around the doors, bonnet and A pillar). The Camry impressed me with the window seals and also the rubber seal on the front bumper.
Overall both look good. The VE obviously have a more muscular look (like comparing a R34 to a Silvia - one muscular the other sleeker). The best thing with the VE was its stance and wheel positioning. It could be just me but I LOVE SHORT OVERHANGS :(:):).
MintR33 what exactly are you saying? Holden’s are popular yes. Not all Holden owners are bogan bums though, same as not all skyline (and other import owners) are teenage hoons. I cant imagine the homeless buying HSV's and Holden v8s........stay off the stereotypes!!!!!
I was saying the new commodore is an over rated hyped up ugly and tiresome vehicle that without the propaganda from local publishing media would have died 20 years ago.
Honestly who can believe in 2006 we are comparing panel gaps "especially around the doors, bonnet and A pillar" to other vehicles that ironed this sort of build quality out when jesus was playing fullback for Nazareth.
Yes the Commodore has it's place, but take away the fact that it is an Australian built car (if it can be called that now) and the that it can be had relatively cheap, what actually makes it so much f*ckn better than everything else?
Mint do a little more research.............type in zeta platform on google.
As a fellow car enthusiast you should have an open mind. Your embarrassing other import owners (including myself) with your stereotypes and your refusal to believe that Australia and Australians can make a good car (not the greatest but a great car none the less).
This afternoon I compared they NEW Camry, the NEW commodore, the NEW Chrysler and also the NEW BMW. BMW first, Holden/Toyota tied, and the Chrysler last in terns of pannel gaps.
Edited by monaroCountry
alloycrap v6 engines are a joke any company who puts a vehicle to market with an engine that unrefined is looking for trouble and anyone who believes that this is ok because it is a marketing gimmick is a fool. who wants to drive a car that is a marketing exercise for the next model. manufacturers strive to produce the best product that they can with the budget that they have and then constantly improve the engine over its life cycle by doinbg research not by downspeccing the engine so that it looksas if they have made an effort on the next model. if thats holdens idea of good marketing then they are doomed or is this just a fanboys claims founded on bullsh$t
alfa romeo and saab do use alloytech engines from holden they use the block only and the importnant parts of the engines ie the heads and all other engine ancillaries are made in house by saab and alfa romeo.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
