hey troy, I just wanted to publicly let you know that this morning on the way to work today I felt this huge pressure down low. Because I got up really early I didnt have time to use the toilet. I really needed to relieve myself and in doing so I let off this gigantic fart, right into your seat. The propulsion of this fart actually lifted me off the seat.
Ive tried vacuuming, spraying, every deodorizing technique I can find, but this smell wont go away.
I nearly suffocated driving home today
Do you still want it back?
Had a look Yvette and I have my GTR Fuel rail but the buggers musn't have given me back the stock Fuel Reg.
You could try the Wanted to Buy section or maybe bite the bullet and by aftermarket for $100-$150 (Sard)
Thanks Sinista32, it seems stock ones don't get given back unfortunately... WidebodyGTR is going up to Sydney this weekend and is going to see if his tuner has one lying around - if not I'll part ways with a few bucks (I'm getting used to that with the 32 ;) ) and buy one. I'm running a Sard now but need to stock it up for engineering. Fun times! :)
Really? It's the first time for me getting a car engineered, so when I was told I'd need a standard fuel pressure reg I accepted what the engineer said. Have you guys had cars engineered with aftermarket regs?
Hey all finily after many of years I'm in a skyline but to get my beast passed for rego I belive my 20" rims won't pass so if any one has a full set of stock with good tyre maybe I could borrow for a day or two
PM'd.
  • 1 month later...
  • 4 weeks later...
Ok just received my vehicle from compliance took it to Dickson and they said this
Tint: Is too much
Exhaust: 94db
Spare wheel needs a sticker
Scissor jack needs a warning sign
Can i borrow someones scissor jack and the spare wheel. Ill have to work out the tint. If possible during the weekend or earlier.
Apparently i dont need an identity check so, just certificate of inspection. Does that mean i can take my car somewhere else where its likely to be passed because they are not some argo shits with hate on imports.
lol - that sucks.
Tint - meh ok if over 30-35%
Exhaust - wow that is so damn close I am seriously impressed.
It's good that it is realy minor mate. I wouldn't be complaining.
All in all an awesome result - but if it just came from being complied I'd take it back to them as it failed.
I have a rego muffler if you want to borrow
Ps no one needs to buy one, this one is never on a car.
Lets call it the community rego muffler
Edited by D.I.Y. Mik
So i toook my car to erindale service center thinking they would pass me but he couldnt do it since its never been registered in Australia.
Im taking it back there hopefully on friday
anyone have a spare jack i can borrow /hire for the day "it will be returned without you having to use force"
also a spare wheel with this 80KPH sticker on it too.
If i dont get a permant fix ill get in touch with you as i dont want to always get pulled over for it.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
