Looks very much like it will be around the Adelaide area....
ah ok thats my neck of the woods :)
after going back and looking @ your car on first looks its OMG very nice but a lot of it is just shinny bling you could possibly get it passed dont quote me on that but yeah iven if you had to return a few things back to get it complied for this state once complied you could pretty much return it as it is now and not get too much grief over it
I'm not 100% sure as its how I bought it. They definately fit fine though, completely flush and pretty sure they are genuine ganador mirrors as they were on the vehicle from japan.
EDIT
Yep! attached is pic of original ganador mirrors
Edited by Hotwire
17x9.5' A-Tech rims with 245/45 rubber. Would look better with some cross drilled brakes behind them :P
Without the silencer, the 3.5" Kakimoto exhaust is louder than a Mack truck!! (and talk about drone central)
Nismo front pipes and hi flow cat help too :)
Polish bay that could look better with a bit of a clean
All taken on Canon 1-D mk3, with either 70-200 f/2.8L USM, 28-70 f/2.8L USM or 16-35mm f/2.8L USM.
Cheers
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
