My 1994 GTST
Is stock standard at the moment pretty much apart from the gtr wing and rear pods, Love the sunroof :D
Are there any photos of r33's with M-Sport kits on them? Thinking about getting one sometime
Dont mind the HSV seat covers, they were only to stop my seat from getting dirty lol i have AMR ones now
Edited by Boostin96
Wheels are Koya Inox in 19's offset?? 235/35 front and 265/30 reara
The bar is a customised GTR 400r bar and made to fit GTS.
C/F bonnet is going soon, and a f/glass nismo in its place.
Just at a guess, probably +35 like mine. 19*8 in +35 is a good fitment.
18x8.5 +22
18x9.5 +22
Pre flared guards
The car is jacked right up in that photo too so doesn't give the full effect...they were sticking out of the guards by a lonnnng way :)
And what size tyres on the rear?
Im thinking of going 18x10 +18 on the rear, looks like it might be a bit of a tight fit after looking at yours :)
it'll be more than a tight fit...those will stick out an extra 10mm over my rears....hope you're prepared to go some major flaring..
rear tires are 265's
Wont be "flaring" the guards, will just be rolling the lip back as much as possible, still not sure on tyres sizes yet, would need to put the rear wheels on the car without tyres to see how wide of a tyre will fit on there, im thinking a 245-255 should fit ok'ish lol
Any chance you have any pics of the full car you could post up? cant wait to see what your car looks like now in a decent pic!
Edited by nizmo_freek
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
