Grant, they are 19x10.5 +21 all round with 275s on all.. hope they fit..
Other Grant, thanks mate :) yeh happy with it just has a couple of minor things to fix up but got it for a good price the body work is fantastic.
Hey Leigh awesome ride! I got a series 3 in black took me ages to find, got gold gtcs as well. The 19s should fit there is a guy in uk that has 19 inch gtcs but he had to mod the guards. There are some photos I put up of it a few pages back. Make sure u put some pics up when u fit em! He has a thread on gtroc, he might have some details of what he had to do to fit them. Enjoy ur ride mate, gtr's are awesome!
It should fit, I have 18x10 +19 with 275/35/18 and I reckon I can fit 18x10.5 +15 in easily.
Put it on and you'll see - don't forgot to take pictures of it while you're at it...
Went out last night with my mate Corbin who's a gun photographer... got some decent shots of my GT-R.
absolutly love your gtr mate!
saw the pictures you posted a few months ago and was very impressed!
Cheers dude :whistling:
serious question the front looks a fair bit higher than the back any reason for that? is that a decal on teh sideskirts in black? hard to tell from pic.
Yeh, that's a decal left over from when the car was vynal'd up with sponsors for a few tarmac events over here.
Height - it's set up for 2 reasons.
1 - Weight transfer to the rear to combat the front-heavy handling issues of the GT-R.
2 - Ground clearance, the Trust extended sump hangs pretty low and I've already smashed one (and in turn had to pull the motor out) on a railway line when the car was lower.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
