  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
http://s1196.photobucket.com/user/adz2332/media/Mobile%20Uploads/received_10208902650220669_zpsigtbb7kk.mp4.html
Hill climb vid
The video doesnt do justice of how steep and tight these turns were! plus its barely a car width wide!
Edited by Adz2332
  • Like 3
Hill climb vid
Car looks mint.
Looks tough with all those blind corners and sweepers. How was the under steer?
yer some corners, by the end, you knew was there even though you couldnt see them. you just had to hold your nerve and power through.
Had a bit of understeer in the real tight stuff right up the top. but on such a narrow track it felt like a huge car compared to it
  • Like 1
This is my 33 after a polish.
Just polished it yesterday aswell.. the 2nd picture is the latest
THat's nice mate....clean in both the sense of the car and the wash!
Care to share what products and steps you did to get it this clean and shining?
Good job.
Good job.
Thanks mate.
I just use the old fashion spray painters trick i was taught when i was panel beating and spray painting..
After the respray i wetsanded with 2000 grit and used some Maguires swirl x remover with a wool pad.
Next step i repeated this process but with maguires ultimate compound with a wool pad - make sure you buff the hazzyness out before polishing.
Now i start the polishing.
I use Autosmart Cherry Glaze.
I apply it to 1 panel at a time nice and thick and with a new wool pad i buff the polish in on a low speed setting untill the hazzyness is gone and its like a mirror.
After iv done that i reapply polish on the car by hand and leave it overnight before wiping it off with a cloth nappy.
Thats how i get the result in the second pic.
Upclose you can tell the difference after its done its like a mirror.
The only think you have to keep doing is polishing after every wash.
The 2nd photo was taken a month ago and i washed the car today for the first time since then and it was dirty but come up like new again and its in the shed with polish on it now ill be getting off before work at 7am in the morning.
Im getting a few touch ups done on the car so ill make a video when im doing it to post on the diy section
  • Like 2
Thanks mate.
Appreciate the sharing mate...definitely an industry trick as it does look very good.
I like how your car is clean. Keep away from any stickers or "ricey" items and you'll be on the straight and narrow! :-)
Thanks again mate.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
