Heres a dyno graph of my RB20....
drop in boost was caused by faulty new BOV(grrrrr) but after removal the tuner called me and said it made around 260 on constant 18psi
ill update the results thread once i get the new graph
turbo is a td06 20g not sure about exhaust housing but most likely 10cm also got all the usual supporting mods
let me know what ya think any opinions are good cheers
https://www.sau.com.au/forums/topic/130813-rb20-powah-full-update-new-graph/
wow what a power curve.
looks good.....how is it to drive?
congrats
funnily enough havent had a chance to drive it.. still a few more days in the workshop for coldstart tuning
and then after that it needs a blueslip n re rego and to get kit fitted so its still probably a month out from being road ready
awsum to see another 2.0l pushin the limits, kw at the wheels is all good and that, but nothing is better then the piece of mind that it can do it without drama's day in day out... go teh rb20. p.s silver 32, where did u get ur front bar? and how much, i got a silver one aswell so its good to compare lol
small but exciting update:
they ran it on 24 psi today and it pulled 280kw at the wheels. hoping to have a graph by tommorow night
he said on the 19 psi which it will be run on usually it was around 250
but should have exact figures and graphs by tommorow
i hugely recommend Nepean District Automotive who are tuning it!!
awesome! its good to see there are still people up to the challenge of getting an RB20 to make good power rather than just folding and getting an RB25 or 26.
I'm in the process of building my RB20 with stronger internals, with all the gear i've got i'll be hitting the 250rwkw mark with more to spare.
even though milk and juice only comes in 2 litres, its the fastest milk and juice
they've ever seen
cheap wine comes in 5 litres for all those holden 5 litre boys :)
keep up the good work
It will be interesting to see how the final tune ends up. Is this the RB with lucky internals?
I am getting so anxious about getting my car back on the road, and the dyno for a checkup with a good EBC and some more boost
Good to see your finally getting the old girl running
Damn how much tuning you done!!! Its on file 203!!
When its all done please show a graph with a boost trace as well.
Good to hear the tuner wants to keep it a few days to sort cold start, thats a good sign.
Congratulations.
Edited by FATGTS-R
hahaha couldnt afford the banana in the tailpipe
engine mods are unknown exactly but sold from jap as being stroked out to 2.2 litres
sadly the 203 is correct... full tune then fuel reg died ... then bov died etc etc... never seems to end
yups has 25 box and hks twin plate
you still keen to get your beast checked out on DrDrifts dyno? i'm free all this week :wave:
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
