Hey everyone, just had a random query, what sex is your car?
My friend calls his car his 'mate', so he concludes it's a boy, but I call my car a girl, because If I'm going hard and fast inside something, it's gonne be female.
Just wondering if anyone else does this, or is it taking enthusiasm a little too far?
https://www.sau.com.au/forums/topic/131131-is-it-your-mate-or-your-baby/
  • Replies 59
I once in a while over heard Saff calling his car YOU SEXY BEAST YOU, RRRRRRRRRRRRR ;).
How did I know when I saw your post it would be to do with me! :)
I had a good comeback but its probably wasteland material. :huh:
Your all crazy....Everyone knows they are bi-curious females looking to pick up. :) :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
LOL.......i garentee if i made this thred the number of insults i would get.....then again this guy didnt say nothing bout a flame thrower bahahhahha.
oh and answering ur question i call it a "it"
mine is gender non descript because I have a beer with my mate when I wash him, and then there are the times when I have eeeer sex with it
so it has balls and tits...
isn't there a word for that?
well mines named after a fire breathing, money hoarding monster and no-one has been good enough to find out what sex it is.
http://www.herrderringe-net.de/kalender/3/smaug.jpg
sounds like a woman...........
