Hi
My car has been above 250kws with the stock trans (+ shift kit and trans cooler) for 18 months running a PFC and has worked very well. The last 6 months it's been above 300 kws . In the interest of getting a high stall, i got Mike at MV auto's to strip my stock trans and do the full rebuild / high stall job. this includes all new larger bands etc.
Now for all the non believers out there that say the PFC wont shift correctly etc. wheres your proof?
When Mike disassembled my stock trans he found that everything inside was in great nick and was all well within specs.
So what other proof does anyone need that the PFC wont harm a S1 auto trans.
i have also installed a set of poncams and backed the boost off to 21psi for smack on 300kws but massive amounts of torque and with the gt3582r-iw im getting 7psi by 3000rpm "Go the auto"
cheers
darren
  • 1 month later...
Well at a recent drag meet put on by another car forum I have done a PB for the 1/4 mile.
11.08 @ 118mph
Im stoked with this time and now i want a 10 before i get rid of the Nissan engine management. I was able to leave the line with 13psi.
Cheers
Steve
RB25+HKS 2535
R33 GTS-t Auto + MV Shift Kit
450 cc Injectors, HKS 256/264 Cams, Wolf3D, etc.
Best ET [email protected] with balding 205 tyres,
this turbo can get you mid 12s with the right suspension and tyres
Editted first post PLUS
Same car, except RB30+HKS 3037 Pro S
435.1rwHp @ 21 psi
[email protected]
With overdrive OFF, it was hitting the rev limitter at top of 3rd Gear
with overdrive ON reached 121.45Mph
'95 R33 GTS-T Auto
PFC
Tomei 740cc injectors
Slide max oversize RB25 turbo
turbo-back exhaust
Walbro pump
Splitfires
FMIC
PRofec B spec-II
Z32 AFM
Adj cam gear
229rwkw at Racepace yesterday however it made 245rwkw but wasn't happy, too much knock. Needs a bigger housing on the turbo according to Ben.
Edited by DivHunter
  • 5 weeks later...
  • 3 months later...
I know i don't have a Skyline, but i do have a Automatic toyota Chaser. It is making 230rwkw on 15psi and i finally ran mine the other night and got a 12.95@110 mph. My 2.134 60fts were ok but my single spinner diff is holding me back. I'll get the diff done, and get some street slicks, and see if i can get that 60ft down to something respectable. With say a 1.9 60ft time and the speed i'm trapping at now, that should put me into mid to low 12's. Not too bad for a daily driver :P
  • 4 weeks later...
i'll add mine. 1995 r33 gtst
with a highflow panel it pulled 145.8 rwkw at RE Customs. the green line is the constant 7 psi boost and the red is factory. she's running fairly rich
the car has now got a trust PE2 catback and will have a full zorst and bleed valve in a few weeks. also will be adding a trans cooler soon and a shift kit later down the track. i'll post up another dyno run when the stuff goes on
184.5rwkw (248rwhp) @11psi with
FMIC
Turbo back 3" exhuast
Hi Flow Cat
Pod Filter ( :( )
22 dollar ebay boost controller
SAFCII
Custom Intercooler pipe kit (swapped the piping over from the usual set up)
Have a stage 2 shift kit, ordering 2800-3000 torque convertor on tuesday.
Then next year i get serious, new turbo, rebuild etc
Chris
  • 3 months later...
Hey Guys , anyone got any new updates ? I ended up hurting the auto (so i though, made noise as you load it up etc during a circuit sprint) , but it turned out to actually be the bloddy hiflow turbo..... of course i figured that one out AFTER i spent over 3K getting Mike doing the toughen up on the auto. Went up to a 3500 stall too. box wasn't to far before it was toast anyway.
Then spent 2.5K on a custom Turbonetics BB to fit into the vg30 rear housing.
Its been 3 months and i've been so busy i haven't had a chance to retune it to suit new turbo..... so thats on its way.... hope to get over the 260 rwkw we made previously. Will let you know how i go soon.
Any of the couple of guys on here at the top had experience with how much you can flow thru a vg30 housing ? and or the std log manifold... anyone had one extrude honed/power ported ?
Gary
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
