thanks for the input. Why exactly am i so slow getting to 0-30km/h and the engine only really starts pulling hard to 100? Cant be that much turbo lag since its only a tiny turbo on the rb25
It's just a side effect of an auto transmission, without a big stall when you leave the line your only slightly above an idle rpm, look at a dyno graph and you'll see how much power (or more importantly torque) your making at a such low rpm. There's your reason why you 0-30 times are so slow
Bigger stall will increase 60 foot times dramatically, but not recommended for a street car as it makes daily commuting a pain in the neck...
Edited by Captain Natro
The converter and turbo need to be matched to each other.
If you want skids, you need to tune the engine for response. The stock turbo and converter should allow wheelspin off the line if it's tuned and setup correctly. It won't happen if you highflow the turbo though.
one more ques , is it best to leave it in D as opposed to using the 1-2-3- to shift because it causes premature wear?
Its bad to downshift hard on a stock auto, it does damage to the fins in the converter.
Though changing manually while in 'power' is better for the trans. Temperatures are generally kept lower when treated this way. But wide open throttle changes can stretch the bands.
A little food for thought
so...ok to shift except not at WOT
  • 4 weeks later...
gents..... had a discussion with scotty about this and it got me thinkin....
who here has a stock turbo and box on an s1 33?
how hard is your change from 1st to second? and do you have a cooler in front of your radiator?
im starting to think im shift kitted already. cos first to second is pretty brutal...
My girlfriend has a 33 with stock box and turbo, full exh fmic 12psi etc.
Her car shifts nicely between 1-2 but still firm. Manual shift in 'power' and it breaks traction on 265s with coilovers. But even then the shifts are firm but still progressive, and it has a small trans cooler over to the drivers side infront of the radiator that looks stock
If it is like a jolt and almost instant then it is likely you have a shift kit.
Theres a video on youtube of a shift kitted 33 with a ratchet shifter for you to compare against
  • 3 months later...
Good day, to all.
I've read almost all posts in this thread, and understand that Nissan RE4ro1 transmission can holds much bigger than 500rwkw.
Could someone explain me please which exact upgrades does it need for that? (Try to wright to Mike from MV automatics, but he seems to be very busy).
Maybe someone knows which upgraded clutches and bands I should use for my transmission (RE4RO1B)? My target is not bigger then 520-550 rwHP.
There is not much information about Re4ro1B transmission upgrade that is why I’m trying to get any useful information.
In advance thank you all, who answered to my message..
This is recent and yet interesting result sent in from a customer running a SS2 turbocharger with a R34 GTT Auto. It was used as a bolton replacement internally gated.
It has:
Blitz front mount return flow cooler
1000 cc injectors
255 pump JJr front pipe
Z32 AFM
Nistune
E85
Stock Auto with a transmission oil cooler
made 300rwkws @ 17psi of boost.
  • 6 months later...
hi
I've got the following mods and am sitting at about 150rwkw :
1997 Skyline R33 GTS25T AUTO
Straight through 3'inch from turbo back
Pod filter
Blitz turnflow cooler
HDI Boost controller
stock turbo
Splitfire coilpacks
I'm planning to install a tranny cooler and hi flow the stock turbo at gcg.
Other then a fuel pump and injectors,what else would I need to do about 230rwkw?
What size injectors would I need? Reccommended brand ? (Saw the Nismo 550c but they are nearly a grand and am only chasing 230rwkw or so and dont want to invest that much in injectors)
Thanks in advance
CHeers
GCG, really? Did you research that one?
Bosch ev14's are the injector you need, go for the 1000's just incase you want more fuel down the track. Grab a Walbro 460L pump too if you haven't replaced it yet.
Bosch ev14's are the injector you need, go for the 1000's just in case you want more fuel down the track. Grab a Walbro 460L pump too if you haven't replaced it yet.
Aren't there disadvantages to getting such a high capacity flowing injector since my desired power level isnt that high as well. 1000 seems a bit excessive?
Yes ive researched and only heard good things about GCG turbo high flows. Have you heard otherwise?
Would I really need such a big capacity pump - looking at the usual Walbro GSS-342 (255lph) I don't ever plan on doing more then 230rwkw..if that)
What kind of transmission cooler is the easiest to fit but will be sufficient to keep the tranny living as long as possible at 230rwkw? ( ive seen craig davies ones , but not sure if they suit my purpose)
The auto will suck 10% of the engine power on average so you need to aim higher than your goal.
What GCG highflow is it, the 3076 cartridge? Why not save 1k and get a more responsive Hypergear? Or just get a proper Garrett that will work as expected... Garrett bearings don't like high back pressure or exhaust heat as you would see stuffing them into mismatched stock housings.
The pump isn't something you want to do twice. Do it once with decent pump, wiring and a relay, it won't cost much more and will give you overhead flow for the next mods. 230kw won't feel fast for long.
Get the largest trans cooler you can, they are never big enough. I run a thermostat on mine to allow the gearbox to warm up quickly.
  • Like 1
Good day, to all.
Give them a call. I just had a Re401b built by MV full manual etc very nice job and reasonable price
cheers
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
