Hi guys,
I bought a BF 1kg extinguisher, with steel mount (with rubber strap and a clip) to hold it in place.
where is the best place that you've found to mount it?
I was thinking maybe directly in front of the passenger seat? (side to side, so the ends would be facing the door and the driver)
Also, how do you mount them? do you cut out some tiny circles of carpet, drill through the floorpan and just use some bolts/nuts? Is there some other way?
Any help would be greatly appreciated
Thanks,
Jason
https://www.sau.com.au/forums/topic/131548-mounting-fire-extinguishers/
Jason, you WISH! :P
Also its probably a lot easier to get at on the drivers side if your upside down and trapped in your belt and you can smell something burning :(
I would think some enterprising metal BASS worker out ther could do some Nissan perfect bracket that would bolt to the existing seat rail screws on both sides for security.
Mine is just a strip of 1" aluminium that uses the front seatbolts to hold it in place. I've had to mount it on the passenger side because the adjuster bar for the Bride rail interferes.
i had done the same, it got quite annoying when ever the front passsenger seat needed to be shifted forwards as there was a wire that kept on getting caught on it. I think mounting to the seat mounts is the way to go though, if you can.
also regarding the plastic strap you have to hold it in, correct me if I'm wrong but I don't think that'll pass CAMS scruitineering, last time i did a day that required a fire extinguisher they said they'd let me through this time, but next time it needs to be a metal strap.
Liz.
2 things.
1 Check out this thread http://www.skylinesaustralia.com/forums/in...howtopic=115536
2 that BFI extinguisher (in the link I just posted) is the only type I'd bother buying. Having used a number of approved ones it's the only 1kg dry powder type I've seen that would actually do any real good.
good choice. it's rated 4 times higher than most of the other "1kg" ones out there. And the strap is not rubber, it's metal, with a rubber cover. :P
edit: if you have a 32 GTST with stock seats you can use the mounted I posted and mount it either passenger side, or drivers side using the factory holes and bolts. I suggest passenger side.
I'll be getting a Monkey Brace for my car so I'll just mount the fire extinguisher onto that (right behind the centre arm rest console). This way I know it's there and all I need to do is turn to the side and reach back.
Hope it works...
I spose it makes it more difficult when mounting stuff like that to a road car used occassionally for race use. Alot easier in a race car where everything is gone...you can just put it anywhere :)
Morgan Park is a CAMS track :D Also heard some really disheartening news about QR possibly not lasting a great deal longer, various financial troubles might see it closing down sometime in the future.....i farking hope that that rumour is bullshit cause thats really limiting the amount of tracks around for racing on :D:P
Edited by r33_racer
You do if you are racing in cams events at morgan park, same at QR (hardly any there anyway cause they run under aasa or whatever it is). Its not so much tracks that are run or owned by cams, but events that are run by cams at that track. The short circuit event i was in the other month at Morgan Park was a cams event and fell under their rules and regs....if you dont believe me, my cams license/ race car log book and scrutineering sticker can confirm this :D
http://bulbeck.com.au/feedback.php?c=0
give them a ring and they can probably let you know where there is a distributor. I know in Sydney Race and Rally (aka speedzone) sell them. Cost is ~$50 for a 1 kg model with metal bracket. They are a great extinguisher able to extinguish 4 times as much fire as most other 1kg extinguishers on the market. Plus they look good. :O
i got mine from "The First Aid Station"... just one of those little stalls that they set up in the shopping centres in the middle of the corridors...
got mine for $44 'coz i explained to the lady what i needed and let her know it was being used for motorsport.... turns out the lady and her husband are avid hillclimbers! :O
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
