  • Replies 84
Well, went to check out the brakes and pricing etc today....and was a little bit more than I thought!
First up you cannot get DBA5000 rotors for the Standard 296mm R32 GTR, so it looks like (If I can cover the cost thru work) I'll be going for the 355mm DBA 5000 Discs's with either Brembo or AP Racing Calipers, with Braided lines, fluid and pads it retails for $10400 for the AP Racing or $9800 for the Brembos.... :)
Edited by PSI_GTSII
i just got the 355mm dba 5000 disks to go with my porsche calipers. There ment to be for a Coon GT :) , I just need to get some shims made up as the coon has a bigger centre bore than the skyline, and a 5mm spacer.
$10400 is heaps, that would be for all 4?
My Porsche setup is looking to cost ~$3900 for the front, and i'm leaving the rears.
Edited by sav man
Yeah thats for all 4, and is retail price, i wont be buying them so they'll be somewhat cheaper @ Trade price.
FTR the guy at the brake place says the Brembos and AP Calipers are similar in Performance but the Brembos offer more W*nk value....?....Never really thought of them like that but as there so similarly priced I prefer the Brembos only because the GTRs came with Brembos.
The 330mm G4 8 Piston Brakes sold by Just Jap for $2499 including Pads brackets and braided lines does seem like good value indeed :P
This looks like the Brembo Package
R32, R33 & R34 BREMBO GT FRONT BRAKE KIT
355MM CROSS DRILLED OR SLOTTED
OPTION OF RED, BLACK OR SILVER CALIPERS
HATS ARE HARD ANNONDISED IN BLACK
BRAIDED LINES, BREMBO PADS,ANNONDISED ALLOY ADAPTERS, INSTRUCTION BOOK, HIGH TENSILE CAP BOLTS ETC
PRICE: $4,795.00 FULL KIT
And this the AP Racing
AP RACING BRAKE KIT FOR NISSAN SKYLINE GTR
COMPLETE 6 PISTON BRAKE UPGRADE KIT
THIS AP RACING FACTORY DEVELOPED KIT INCLUDES:
1 PAIR OF 2 PIECE STRAP DRIVE FLOATING 343MM DISCS TO SUIT 17" OEM WHEELS OR 355MM DISCS TO SUIT 18" OR LARGER AFTERMARKET WHEELS
1 PAIR OF CALIPER MOUNT BRACKETS
1 PAIR OF AP 6 PISTON CALIPERS
BRAIDED LINES
HARD PIPING AND BANJO ADAPTER FOR SKYLINE GTR
FERODO RACING DS2500 BRAKE PADS
ALL HARDWARE REQUIRED FOR ASSEMBLY
2 BOTTLES OF DOT 5.1 BRAKE FLUID
PRICE: $5,200.00
Ok going down to order these brakes.
So of the 2 Brake options shown above (AP Racing or Brembo) whats the general consensus on which is best, i'm leaning towards the Brembos purely to keep with the factory theme, but am not really fussed either way.
Which do you guys reckon is the way to go...?
Also the bloke down there wants to buy my old Cross drilled 296mm discs and factory calipers...what do you reckon they are worth as I have no idea!...?
Cheers
Edited by PSI_GTSII
I once drove a 33 gtr with that AP set up on the front and nearly creamed myself, I loved them!
AP is just as much a reputable brand as Brembo!
I think you need to upgrade the master cylinder on 32 gtr's when you have bigger callipers don't you?
Edited by gtr fan
Go round the corners faster and you don’t need to waste that sort of money on braking hardware. Spend the money on suspension and circuit driver training and I bet you do faster lap times.
:) cheers :rofl:
well on my 32 GTR I have the following:
DBA 4000 series rotoros front and rear
Endless Carbon/ceramic CC-R pads front and rear
cusco master cylinder brace
nismo braided lines
motul RBF600 fluid
cut off the front stone guards
and i'm still not completely happy. running on yokohama A048 semis on 17X9 inch rims.
not sure what i'll do next.
:) cheers :rofl:
Could'nt agree more :D
I have just bought some Semi Slicks, will concentrate on suspension next.....brakes are costing me nothing, work is paying (salarys sh*t so have to have perks!)
Ended up getting the Brembo's, they are slightly cheaper than the AP and the disk size was bigger 355mm vs 343mm although the AP Caliper is a 6 piston jobbie, and the Brembo only a 4, there is also a 3 week wait to import either of them.
The ap calipers don't have piston dust seals so are not suited to street driving.
not true - CP5555 are a road caliper and have dust seals... http://www.apracing.com/roadcar/caliper/da...p?family=CP5555
what is the thickness on the rotor on the brembo kit?
it's not all diameter... my APs are 355x36mm - most 355 i've found are 32mm thick
that extra mass (should) make a difference as you've got greater heat capacity
I made this thread awhile ago and got alot of comments back from the guys in the know. Have a read through it as its got alot of great advice :D
Click Me!
That was a good read thankyou :)
Alot of you guys are very serious about your brakes and suspension setups!
So in summary, for an R32 GTR that is to be street driven, has under 250rwKWs, and is occasionally to be used in short Hillclimbs, Club style Track days against the clock and Motorkhanas
(And i'm Guessing the majority of 32 GTR owners fall into this catagory)
The best brake upgrade would be:
Motul RBF600 fluid
DBA4000 replacement rotors
(Retaining original Calipers)
Ferado DS2500 pads
Some detail that a lot of people forget....oh and I recommend you look into RS73s group but for RDA discs.
Car & Driver did a test a few years ago ...Test Car was a WRX (US Spec which only uses two piston sliding caliper, not as good as Nissan 4 spot or later Model WRX 4 pots)
So tested kits were, std car, std car with upgraded pads and fluid, Brembo F50 Kit, Brembo Lotus Kit (Similar to as fitted to GTRs, 44/38mm pistons), Stoptech it and Prodrive Kit (Alcon)
Stopping Distances 70mph - 0 , 3 Stop
Brembo F50;_____________ 185 / 183 (Average / Best)
Brembo Lotus; ______________ 200 / 196
Prodrive; __________________ 198 / 194
StopTech;__________________ 187 / 186
Stock; ____________________ 205 / 196
Stck with pads and fluid; ____187 / 184
The above figures are all in feet, one stop difference between pad and fluid upgrade to crappy sliding caliper brake setup and massive Brembos is 1 ft...lol 30cms:( And over 3 stops the average is 2 ft...lol 60cms:)
So you can see the one stop max of the upgraded pads and fluid is damn good when you consider the $$$ to % difference.
Stopping Distances 100mph - 0 , 25 Stop
Brembo F50; _____________ 299 / 288 (Average / Best)
Brembo Lotus; ______________305 / 294
Prodrive; __________________ 308 / 295
StopTech;__________________ 297 / 290
Stock;_____________________ 340/317
Stck with pads and fluid;_____316/299
Not the world of difference you would be led to believe by the "you need 6pot caliper 343mm rotor crowd."
Specs of the kits:
Rotor Weight (pounds) Size in inches (diam / thk)
Brembo F50;.................15.8......................... .13.1 / 1.3
Brembo Lotus;..............12.9.......................... 12.9 / 1.1
Prodrive;......................16.5...........................13.0 / 1.1
StopTech;...................13.9..........................12.9 / 1.1
Stock;.................. ......14.2..........................11.6 / 0.9
Caliper Weight , Piston Size, (mm)
Brembo F50;..........8.6 pounds...........40 / 44, Leading / Trailing
Brembo Lotus;.......6.8.......................36 / 40
Prodrive;...............9.1..................... 34.9 / 41.3
StopTech;.............9.3.....................36 / 40
Stock;.................10.8.................. .43 / 43
...and COST!!!
Brembo F50;.......................US$2,995
Brembo Lotus;.....................US$2,595
Prodrive;.............................US$1,999
StopTech;...........................US$1,695
Stock with pads & fluid;....... US$130
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
