Merry Christmas "J" and others who have served this thread so well for so long!
If you said that you've worn down the finger prints off your fingers I'd be inclined to believe you!
Thanks "T" :D
  • 3 weeks later...
Can anyone tell me if my gtr le mans is in fact a genuine le mans? All numbers match, but doesnt have dual airbags? Vin plate details:
E-BCNR33
Chassis number: BCNR33-023007
Model: GGJPRQFR33ZDA-ARAA
BT2 K
RB26DETT 2568 CC
FS5R30A RC41
5
Help would be greatly appreciated :) only bought 3 weeks ago but after researching more and more finding out i may have bought a non gen le mans. Still a gtr so is still a nice car but still, wanna know what i have. Thanks.
E-BCNR33
BT2 K
RB26DETT 2568 CC
FS5R30A RC41
5
I'd say so.
BT2 = Champion Blue from factory were only allocated to the Le Mans Editions.
Thanks mate :) just now need to know why mine has a series 1 dash :/ lol
I'd say because your R33 GTR was built in June '96.
From memory:
Series 1 = 1995 - 1996 - No passenger air bag, only air bag on steering wheel.
Series 2 = 1996 (Late) - 1998 - Has Passenger Air Bag and updated steering wheel (I think?)
Series 3 = 1997 - 1998 - Has what the Series 2 got + Xenon Head Lights, red stitching on seats, lower front lip and twin air vents on the front bar to vent more air to the intercooler.
  • 2 months later...
Guys, I am having trouble with the 64-bit version of the Nissan FAST software. I have input the VIN, the model number comes up and I can search, but I only get the "Part Code" and not the "Part Number". Can someone explain how to get the part numbers to display?
You have to press 'part no. search' up the top (looks like an open book) and it will output the part number and bring up a prompt if there is more than one part for that part code
  • Like 1
Hi Guys
Can someone look this one up for me?
BCNR33-007638
GGJPRWFR33ZDA-J---
Thanks
BCNR33-007638
GGJPRWFR33ZDA-J---
V-Spec (Series 1)
1995-06
KL0 Spark Silver Metallic
V-Spec (Series 1) With A Rear Wiper
GTR-Registry.com has more info.
  • 3 months later...
  • 11 months later...
I've posted this in the other "Downloading FAST" thread as well, but no answer yet. Can anyone else with FAST tell me what your program and CD dates are (> Help / Version Info) ?  I have recently acquired a 2004 model car but my CD's only go up to 2001/10.  I spent two hours downloading what was labelled as "FAST2010", but I think they typo'ed the name because it was same as what I already had, 2001, not '2010'.  Does anyone have FAST with CD's later than 2001/10?
  • 2 months later...
Hi Strutto ...
I have a question, maybe you can help me out here... ?
I used to be A authorised Nissan workshop and had Fast at the time, but I cant seem to get fast working with Win. 10. Also we are located in Denmark so we have the european disc for Fast. Anyway...
I have this R32 / chassis nr: BNR32-013497 from 12/1990 , an "early" model.
It is imported from Malaysia, and came with a nissan GTR steering wheel - I noticed when driving for some time 20 minutes or so, that the steering jumped - no Hicas light came on - but the rear wheel turned slightly when it was supposed to be straight.
checked the Hicas with a Nissan Consult II tester - No faults but read 153 degres to the left on steering angel sensor when the steering wheel was straight,
I took the steering wheel off, and yes it was the new type with the holes at 12 & 6.
when I lign the steering angel sensor up with the middle point of the neutral signal it of course lines up at 1 & 6 o'clock.
So I have the "early" type of steering angel sensor and the new type steering wheel...
I have looked at some parts catalog pages, and seemed to have found that the early steering angel sensor should
be part number: 28475-01U00 or alternative number: B8475-01U00. (there are no number readable on the sensor equipped)
The Question is I think I have found the later version of steering angel sensor equipped from 09/1991 -  models
wich should have the number 28475-01U11 or alternative number:  B8475-01U11.
Do you know if this number are for an sensor with alignment 12/6 o'clock and does it fit on the car with the early version´s ?
Cause Nissan europe cant confirm this for me.
If I could buy the new type sensor that fits the steering wheel, then I can get the Hicas working with the steering wheel at the right position, right now I drive around with the steering wheel turned 153 degrees and the Hicas works superb.
Hope you have the answer for this - best regards Lars.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
