Yeah, both front and rear uni's look to be beefier than the ones on the 33 tail shaft. Rear one is rebuildable, front one isn't.
If you think 575 was pricey, I was quoted up to $1200 from other places.
I have a 33 speedo drive which i have adapted to the back of a 32 speedo face, in the process of jury rigging it atm to see if i can get it working before hacking up the back of the dash. If i cant get it, then the navara drive goes in. Only concern then is physically fitting the cable up to the drive as there isn't much space in there.
  • Replies 188
Posted Images
$1200!!! Made of carbon and balanced to 400kmh??? Far out some people think they can have a lend.
I guess mine did have problems at first, and in the end they had to pay to put the better unis on not me, which I would have had no problems paying in the first place, but as they say thats the way the cock flops.
Well after a week of mucking around with the r33 cluster and then an s13 one just in case the 33 one was cactus i grabbed a 32gtr drive (thanks risking) and used that.
The shaft is about 10mm shorter than the VL/navara unit so that you get away without removing the key way. and the bottom section of the gear is a nice interference fit over the splines requiring the bench vice to press the gear on. I just chucked a bit of loctite on the splines before installing.
I found that i also had to cut a new slot but only about 120 degrees around, rather than 180 as booster suggested.
Also bashed the bottom edge of the tunnel a bit to give a straighter shot at the drive for the cable.
Has anyone had cable failures due to the tight bends? or has anyone gotten a replacement shorter cable to suit the different drive position?
Edited by BHDave
How much would a mechanic charge to fit a r33 gearbox into a r32?
Thanks
Well, my total conversion cost about $3400... But that included the box and a jim berry clutch, and the one peice tailshaft, not that that cost much more than getting the standard one modded.
So say minus $1400 for the box $1200 for the clutch, mine cost $800 or so, inc the tailshaft, and a few misc bits. But thats also removing the existing box, and he had never done the conversion on a cefiro, so there was a little experimentation time.
  • 2 months later...
i went to nissan today they dont make the r33 speedo cog anymore, or the whole drive!!! and they dont make the navara pinion assembly with the 21 tooth cog..
does any1 have a spare r33 pinion assembly? or are any others the same? i only want the cog off it!!
my tailshaft only costed me $100 i used my r32 tailshaft and just put the yoke off the r33 tailshaft on it..
Tried it, couldn't find the info on how it's wired, wasn't lucky enough to guess it.
r33 speedo has 4 contacts on the back, one positive, one neg, and what i think is a signal in and a signal out. The speed sensor is a hall effect from memory which means both wires will give a signal, provided the other one is earthed. So through educated guess you can figure what has to go to the dash. Without tracing wires through an r33 you don't know what has to happen in between, which was the point i decided it was all too hard.
The dash requires butchering to fit the 33 speedo mechanism. it's a harder job than chopping off a cog and sticking a the 25 one on there
  • 1 month later...
So to round up the three pages what steps or items are needed to do this conversion?
Longer size bell hosing bolts, what sizes?
Tail shaft with R33 yoke, whats best or cheapest, custom one peice or mod the stock R32 one?
Cluch slave. Does anything need to be done to the bearing, housing or clutch fork?
Without going into debate, is there one setup for the speedo drive that has worked without trouble?
A custom cross member, anyone have a pic of theirs?
Slight change of trans tunnel shape, pics?
thanks
Daniel
(starting to sound like its gonna take me more than a morning to do this)
Edited by =premo=
I found a place in NZ who does a replacement part to convert the r33 box speedo to suit r32
I spoke to him today and mentioned Navara parts and he said he didnt use them yet mentioned it was genuine nissan and they had never had problems.
75 NZD and www.dodsonmotorsport.com
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
