can anyone help out... im trying to find a specific park like i said its in the ryde area... its on the victoria rd side or parra river and is right on the river... the only thing i remember about it was it had a huge rope pyramid, i totally forget how to get there... can anyone give me a street name or the name of the park... its a good place to make out with my man friend thats all :rolleyes:
thanks
https://www.sau.com.au/forums/topic/135460-im-trying-to-find-a-park/
can anyone help out... im trying to find a specific park like i said its in the ryde area... its on the victoria rd side or parra river and is right on the river... the only thing i remember about it was it had a huge rope pyramid, i totally forget how to get there... can anyone give me a street name or the name of the park... its a good place to make out thats all :rolleyes:
thanks
are you attempting a new twist on the cum stain thread?
sorry dunno any parks in the ryde area with a rope pyramid.
yeh tried all those couldn't find em... oh well shit happens...
sif an R31 wagon is 'fully quick' lol
anyway mate, try www.whereis.com.au
it is when you have a rb25det neo in it... at least i went out and bought a stock car and made it unique instead of buying someone elses junk... eat a dick mate
Ahh- one of the 'built not bought' crew, eh?
FYI- a crappy old aus spec R31 wagon with a good engine is just that: a good engine trapped inside a shitbox.
Now head off back to space....goat.
can anyone help out... im trying to find a specific park like i said its in the ryde area... its on the victoria rd side or parra river and is right on the river... the only thing i remember about it was it had a huge rope pyramid, i totally forget how to get there... can anyone give me a street name or the name of the park... its a good place to make out thats all :(
thanks
Cant see much in the pic but this is Kissing Point/Putney park...
hmm that a little low to the water
and im pretty sure there isnt a parking plave there.. its off the road, big slide and stuff there as well..
Im pretty sure its not far from the Ryde Pools and maccas @ gladesville
can anyone help out... im trying to find a specific park like i said its in the ryde area... its on the victoria rd side or parra river and is right on the river... the only thing i remember about it was it had a huge rope pyramid, i totally forget how to get there... can anyone give me a street name or the name of the park... its a good place to make out thats all :dry:
thanks
Is it school holidays already?
I dont know of any parks with a rope setup around there - sorry cant help
