Front lip is being respayed soon
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
My cars booked in to finally get the key scratch fixed on the 9th of October, whilst its there I'm getting my front lower lip resprayed as its chiped an cracked.....stupid witches hats...lol
I was going to get it resprayed the same as it is (white), but a friend thinks I should do it black. what are your thoughts?
cheers
Berin
https://www.sau.com.au/forums/topic/136029-front-lip-is-being-respayed-soon/
ever wondered why GTR's have them matte black from the factory? Because they get hammered in no time when they're colour coded. I've resprayed my one from gloss to matte black. Looks much better IMHO and after week of driving, won't look all marked from small rocks.
I've had to respray the lower lip twice since i've owned the car, an it doesnt really bother me as it doesnt cost a lot to do, I just detatch it and take it in.
I might also add that in a week or 2 im getting the rims powdercoated gloss black as I'm over the grey.
ooo, let me know how much the blackening of the rims costs... i'm very keen to do this... not sure if i want to go gloss or matte...
would they need the car for a whole day or more to do it?
If respray doesnt bother you, get it black, see if your like it, if not respray it back to white :)
well I'm getting mine done through a freind....beers worth more than money ;)...hehe
but I got quoted around the $25 per rim to powdercoat (place's round Geelong) plus whatever sandblasting costs.
when I had mine done originally a few years back it cost me $60 per rim including sandblasting, I took the rims in to them in the morning and picked them up that same afternoon. Coating places wont do the work for you, there not mechanics and dont have tyre machines, so you'll need to organise taking them off your car, getting the tyres stripped off at your local tyre shop as well as removing the valves an any wheel weights, then take the rims to them as bare rims.
Hope thats of some help. Cheers
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
