So as some of you know, I work for ACP Magazines and this week lil blu had a cameo photo from Dutton Rally Vic in Auto Action.
I was quite disapointed with the shot and called the National Ad Manager who works on all of the Autmotive magazines (Auto Action,Wheels,Motor & Street Machine) to jokingly complain about how shitty my photo was in this weeks magazine.
I sent him a heap shots and told him to get his editors to make it up to me in the next issue of Wheels which will have coverage of dutton in it.
So the editorial team came back with this to cheer me up! Im still working on them to put my car into the next wheels, but this certainly made me laugh.
:laugh: :laugh: hehehe!!
:happy:
Cover_1174.pdf
https://www.sau.com.au/forums/topic/136625-auto-action-p/
:P - i cant get the stupid picture to open.
Will try to look at it at home over the weekend.
Stupid works computers, or stupid me maybe, im not sure :P
But YAY JUZ - im sure it looks ace!
Right click and Save Target As
Its about 3.5MB so will take a while to open and actually locked up the first time I tried it. :)
https://www.sau.com.au/forums/topic/136625-auto-action-p/#findComment-2540252
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
