All interested drivers,
As some back ground info, I did a private practise drive day out at OP last month, it was gold. I had an open track and only 4 other cars driving! I had the track to myself, no marshals, no sessions it could not get better. I was incapable of driving anymore laps by 3pm due to exhaustion!
I placed a call this morning to check if they had any more planned days, and apparently there were some cancellations that enabled a few day’s to open up, below is the response I received.
Sat 7th Oct 06, South cct. $110
Mon 16th Oct 06, South cct. $110
Tue 17th Oct 06, GP cct. $110
Wed 18th Oct 06, South cct. PM only $50
Thursday 19th Oct 06, GP cct. $110
As per all CAMS days you need a CAMS Race or L2S licence, helmet, non flammable clothing and a road/track worthy car. Last time I went, they did not even look at my car or helmet, so there is some level of trust.
I would encourage everyone check with Oran Park the day before on 0246461004, to ensure it is still being run.
I think I might do either the 18th and or the 19th Oct.
See you out there!, why own a high performance car and not use it, there is no excuse?
  • Replies 86
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
