Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
i got a chrysler gallant
its got a custom exhaust (i cut it myself)
single down drought carbie(vacuum secondaries dont work)
and blown piston ring
"power" my guess bout 30kw at the rears lol
  • 1 month later...
Model - Swift
Engine - G13B
Modifications - Extractors, exhaust, cold air intake, BD14 cams, cam gears, Enlarged throttle body, group A chip, remapped ecu, dog box, msd coil set,
Dyno tune results 54kilowats before, 88 kilowats after
there was man other mods i just forget,
high 14 pass.
  • 3 weeks later...
put the pulsar on my mates dyno last night. made about 82kw, about 2kw down on what it made on a different dyno about 6 years ago. plenty of power left in it though. AFR's are mid 11's. now to convince the missus to let me put a nistune on it.....
  • 4 weeks later...
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :P Hopping for 185rwkw
Finaly got the car on the dyno after getting the extractors and light wieght pulleys.
191rwkw now. Pushing for 200 :rofl2:
  • 3 weeks later...
  • 1 month later...
Some history on the RB20DE in the rally car:
Come a long way from it's first run of 97.5kw!
Spec's are:
RB20DE (235,000km)
Independent throttles (4AGE)
Ported head
Cams (270 or 280° can't remember)
Link G4
8,400rpm Rev limiter inguaged 4176 times in 2 years. That's not counting bouncing off the limit either. Rev it much?! :)
Z32 NA with exhaust/extractors/pod/chip yielded 240kw
My R32 with similar mods dynoed 222kw.
Battling to extract more though.
Errrrm...i think you were meant to say horsepower...240rwkws is somthing like 320-330kws at the flywheel.
I think he's just talking crap as a Z32 NA will all that wont make 240rwhp/rwkw in any case.
Rb30e
Today I made:
97.5rwkw @ 120kph
321nm @ 88kph
Rev Limiter @ 6500rpm
Specs:
Stock RB30E
Stock Timing (+15)
91 Fuel
Extractors & 2.5" Exhaust, Stock Cat & 1 Muffler Before Diff
3" Intake Pipe, Cheap Pod, Custom Airbox & CAI.
Going to run it on 98 Fuel Next time & +20 Timing, aiming for 100rwkw, also need to sort out the issue with it running rich.
  • 4 weeks later...
94 r33
rb25de
stainless steel extractors, cat back, apexi pod.
95.7rwkw...
update today i got 101.7rwkw with new catbak and timing advance in 4th gear run
what size exhaust do you have from the headers? and what size from the cat back?
  • 1 month later...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
