A quick guide to understanding Rim Offset / wheel offset for those of you buying some new rims for your cars, as the wrong offset can make a set of rims either not fit at all, or just not give you the right look :D Its all pretty simple, and the pic should be a huge help :P
...and...
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
ZERO OFFSET
The hub mounting surface is even with the centerline of the wheel.
POSITIVE OFFSET
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
NEGATIVE OFFSET
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
Meggala's nissan wheel offset guide.
Meggalas Nissan Wheel Offset Guide - COVERS ALL IMPORTS,(linky)
https://www.sau.com.au/forums/topic/138435-wheel-offset-guide/
  • 11 months later...
Something that is also very useful is the offset calculator. Give you a measurement of the difference between your current wheels and your new rims. Will help you work out if those new rims will fit - clicky
  • 5 weeks later...
http://marksink.com/tire_wheel_offset/offset.html
heres another offset calc. im not sure if its the same but i thought that the first one used to be accessible. i have used it b4 w/o needing to log on
and another
http://www.driftworks.com/resources/wheel-...culator,17.html
  • 4 weeks later...
  • 3 months later...
  • 8 months later...
  • 5 weeks later...
Just as important as the offset is the disk type for some Japanese rims, or just the clearance for rims in general - make sure the spokes clear the brake calipers before you pay for them.
Made an expensive mistake in ordering Volk GT-Cs which arrived with a B-disk type which didn't clear the stock Brembos on the front of my R33 GTR.
Matt
  • 1 month later...
  • 2 months later...
  • 1 month later...
  • 3 months later...
  • 3 months later...
  • 4 weeks later...
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
