hey guys not sure if this is the right section of forums to post this but meh, here it goes. just wondering what these bits are meant to help, my understanding is less flew of engine= better power to ground/ less strain on mounts? lil help here, http://www.justjap.com/parts_nengaccess.htm
Edited by dead32
https://www.sau.com.au/forums/topic/138565-engine-damper/
I thougut that all an engine dampener did was help to stop cracking engine mounts (and brake booster vaccuum hoses, but thats another story).
so less IMPACT on mounts (resists sudden changes), same strain...
as to "more power on the ground" - only if you drop the engine out.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-2581604
  • 3 months later...
Topaz, I hate it when that happens.
My cheaparse compliance mob (who charged me 5k for compliance) replaced my charcoal can with this big mofo one, and it's mounted right where the dipstick is.
you'd think that paying them 5k, they wouldn't skimp on a fricken nissan catchcan.
Yes, I will name and shame you compliance mob. just watch.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-2875492
well I wanted one because I thought they look cool. but having asked people in the know in japan their response when asked about the benefit of an engine damper was: "looks only part" ie, it's only purpose is to look good. if you want less engine movement, buy some nismo engine mounts. money well spent there. note the guy that told me this sells them in his shop so by him telling me they are no good it was one less thing for me to buy, but he gave his honest opinion and he knows his shit so I took the advice and left it on the shelf.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-2876023
I had one, took it off recently as it's rubbing up against my oil filter. After taking it off I felt no difference at all.
Main reason to get one is looks, 2nd is PERHAPS they might help to make your engine mounts last longer. I am not 100% sure on this theory though.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-2876895
  • 4 months later...
I just change into Nismo Engine & gearbox mounts for my GTT. Wondering whether anyone has experienced more vibration than the stock ones? I can feel it when i rest my feet on the rest pedal, doors (when opened), fenders, etc. Basically most on the front half portion of the car while idling. I was told it is normal because the Nismo are made from harder compound rubber but will feel less vibration once they aged. Pls advice cos i hope the install was done right.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-3192044
Well think about it. You put in mounts that let the engine move less, of course they are a harder compound, of course you will get more vibration through your car. The engine mounts are there partially to absorb those vibrations. By putting a more rigid one on you will send more of those vibrations through the car.
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-3192241
Agreed :cheers:
  • Like 1
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-3192869
Having said that, when I put them in I didn't notice a significant difference.
You can't really do engine mounts wrong they are either in or not, maybe check the nuts are on tight but thats about the only thing that can go wrong.
When you feel it vibrating is it in gear (auto maybe?) is the engine idling smooth or too low or too high?
https://www.sau.com.au/forums/topic/138565-engine-damper/#findComment-3193813
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
