From www.drive.com.au
The Sportivo looks sensational (lots borrowed from Lexus) (production version)
Base a bit hard to swallow:
More pics
http://www.drive.com.au/Editorial/ArticleD...articleID=20878
From Drive.com.au
-The 336Nm of torque isn't available until right up at 4700rpm, so our initial brief evaluation uncovered that it isn't overloaded with effortless low-down performance
-Left to its own devices in "D" for Drive, the six-speed isn't always as smart as it needs to be, often too eager to shift up a gear in hilly, twisty terrain. It's not long before it's jumping back down a ratio or two to keep the large sedan motoring along.
-Despite claims of sportiness, the Aurion is more adept at cruising rather than enthusiastic driving.
-The steering can sometimes feel a bit numb and get some mild kickback on very bumpy corners. The seats could also do with more lateral support, something forthcoming on only the Sportivo models.
Sportivo ZR6 $42k thats almost XR6 Turbo playing field! I wonder what sort of power its got?
  • Replies 66
I think that's the rumoured supercharged V6 they've been going on about
If they're going to throw a supercharged V6 Camry looking FWD thing into the market and expect it to make a huge dent in the sales of XR6 Turbos and SV6 Commodores then they've got another think coming if you ask me
Make a rwd, 6 speed manual with a ... 3jzgte (3 for greater than 3 litre; ie 4 Litre :O:):P) Make it weigh less than 1400 kg, and cost less than its competitors, and i will buy the first 50,000. Ps Has to look Sh!t hot, and have a coupe variant.
Also, V config engines are gay. Straight config engines are straight :rofl:
Edited by Mulkers
Have you seen this thing on the road.
The rear tail-light look like they are on the outside of the car. :O
It is just another washing -machine wanting to be a Plasma TV.or sorry LCD Screen.
But hey Toyota's sell even if they look ok....people buy them for their reliability.
I think though this is to steep if they are asking 40K plus for something FWD and no Turbo
that is medium in size.
If they made it AWD like the Subarus they would sell shit loads :P
... the FWD aspect kills it
Whats Toyotas problem anyway... why fight the system?
Just make it RWD and everybody will be happy
There are a few Large RWD Japanese cars by Nissan (Fuga) and Toyota (Mark X) etc that would scare Holden/Ford into solely making Taxi's. The only trouble is they aren't specced as lowly as the Commondore and Falcon, and by the time they got here, the base bare-bones models (if they existed) would be mid $30K range... not price competitive.
Wow, never knew about the Mark X before:
http://www.mark-x.com/
I'd buy it!
well if all goes to plan they'll be eligible for import in the next year :( That, and the Gloria/Cedric/Cima combo from Nissan... unfortunately none of these cars appeal to the common buyer in australia because they're not "locally sold"... but if you compare em to the garbage thats sold locally they're leagues ahead. Shame really.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
