i reckon the G35 pictured....should have the bumper with a slightly higher angle so it mates better with the bonnet line...
from the side it looks as if there is a dip where they meet.. i can also see there is like a mini vent/grill/hole there for getting to the bonnet latch.. that should have been shaped to meet the bonnet better..
thats all...
not like i could do it
but every time u look at that car in the driveway/garage u would be thinking its not quite an Aston and not quite a skyline ;-)
Why would anybody bother???
There is only one Aston Martin worth owning in my books and that's a 1969/72 DBSV8.
Anything that can go from 0 to 100mph and back to 0 in about the same time as we can walk across the road will do me (13.8 secs)
A good one can be bought today for under $50,000.00 so compared to anything Nissan it represents good value.
Anyway, it is one of the last true Aston Martins, as Ford bought a controlling interest in about 1975. Just look at the current series, all are 5.0L not the 5.3L Quad Cam of these classics.
Cheers, D
Cheers, D
Nice car, but there are other nice Aston's... V8 Vantage Le Mans? 600hp from twin supercharged V8, and it looks pretty mean...
And what about the DB5? Who wouldn't want to drive the difinitive Bond-mobile?
Edited by Big Rizza
Almost as bad as when people use to put mercedes front grills on geminis.
Or the whole evoIII body kit phase of the late 90s. No your excel is not an EVO!
The only decent one of these kits ive ever seen that makes a car something its not is an mx5 converted to hardtop and made to look like the very first rotor - 110s cosmo (had a big 10A in it).
original looked like this:
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
