Update: Hot4s not coming anymore, so anyone with a camera rock up, hopefully get some decent pics still.
damn. oh well not to worry. will still be getting photos of my own. hopefully i'll get a couple good ones. :P
  • Replies 208
Well the photo shoot turned out good after all you impatient buggers took off home.
Got 21 cars all in a big arc. Will post up some pics once I've defaced them of plate numbers.
I've got a heep of picks to, just need someone to stitch them together, any volenteers???? I'll post some of the single ones tomorrow night as i won't get a chance today;)
PM me if you can stich the photos for me and i'll email them to you.
Thanks
lol so more ppls turned up :( i figurred that was it when all those others left
Thanks
Give this app a burl yourself, supposed to be pretty good...
http://www.cs.ubc.ca/~mbrown/autostitch/autostitch.html
Yeah was a good turn out in the end, got about 10-15 around 5pm, then after 6pm had 21 for final shoot, will have to organise it a little better next time. My bad
yeah spewn dunno what time we left but had i know i might of stayed... not to worry Sir32 says theres an even better place for photos up near the boat ramp maybee we check that out
mr_rbman - how come all your pics are so small 320x240 :cheers: even 2mp mobile phones take 1280x1024
cause i'm not too good with comp's and i just resize them so they don't take forever to upload and they always end up too small!
Use the microsoft picture resizer.. pretty easy to use.. Just highlight all the files you want to resize (by holding the shift or ctrl button) and then right click the mouse and select resize. :cheers:
640x480 is a fairly good size if you are on 56k.
Then if possible upload to SAU. ;)
i did but after i installed it i tried to use it and it just kept trying to install itself again and again, i am on broadband (512 i think)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
