Anytime man. I need an excuse to go take some pics. Just let me know when so I can work out a good spot to shoot your car. Should be alright. It's much harder to shoot mine cause it really needs to be shot in a dark place, white cars are a bit easier :)
Lol all them parts cost me a lot of money back in the day and that was when the Yen was 105 to our dollar and it was still expensive as shit.
Genuine Abflug Carbon Rear Diffuser i want $700 for it, cost me over $1500 back in the day.
Genuine Autoselect Carbon Chibi Devil Wing i want $650, cost me $850.
Genuine Series 3 Xenon Lights Brand New i want $2000 they are worth over $3000 if you had to get them from Nissan, will fit GTST's as far as i know.
R34 N1 Nur RB26, has done 25,000kms Bare engine, no turbo or intake PM me for more specs on engine $9000.
OS Giken Triple Plate Clutch still in very good condition with push, pull converter $2000 worth over $3500 New.
Heaps of other shit to come
Ben, are you selling your turbos? What are they? How many kms, etc?
Yeah Jono was gonna try sell them as a kit Tomei Expreme Manifolds, HKS 2530's with HKS 1.3Bar Wastegates, and HKS Dump Pipes. all have been Ceremic Coated in Chrome and have not been used since they were done. They have done approx 15,000Kms. Asking $3200 for the lot.
Also have a Full Titanium Exhaust System as well.
-Sunline Racing GT Spec Titanium Front Pipe BRAND NEW Never Been Used - $1200 is I Payed Way more rolleyes.gif
-Greddy 90mm Titanium Catback Straight Through Used but in very good condition - $1000
do it phil!
looks good cal. phil i think you should start the carbon whore group :3some:
does anyone else think its time the mods just merged the mackay & townsville threads into a nth qld thread?
I have heaps of other shit for sale i pretty much want everything sold off the car so it is just a rolling chassis, my brother and I want to start another project car. After all the stuff we learnt building the R32 we think we can built a top level time attack car which will be more extreme than the R32 in nearly every way and will probably take another 3 years to do. So everything thing must go.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
