ok guys ,
for a limited time only i will be offering a 3 " custom mandrel bent stainless steel cat back exhaust ( you supply muffler of your choice ) for $550.
i now have my workshop and although i have stuff to sort out and a house to move into i also want to finally get busy and make a little money .
can use exsisting muffler if you wish as long as it is big enough and as its custom made it will be designed to sit as high as possible to avoid clearance problems.
kermit
  • Replies 353
Posted Images
got my 32 back from kermit today, had FMIC and dump pipe installed. VERY happy :)
car runs awesome, both items were installed perfectly and even though the FMIC caused some problems kermit was awesome and kept me informed with what was going on at all times, Illl be seeing him again for an intake pipe and BOV fitment :( great guy and great work !
what are screamer pipes?? i got a 4.5 inch tip on my cannon how much if i was going to get a 5 inch cannon??
ummm some mufflers are interchangable with their tips , most are not though . i would suggest a new muffler if you are that keen on a bigger tip.
kermit
ok guys ,
i now have my workshop , based in Girrawheen , behind my rental property. i will be setting up the workshop this week but i am ready immediately to carry out any work you require. i have enough stock of parts to do 5 cat back exhaust systems so if anyone wants one ( special price of $550 ) these can be started straight away and take a day to produce . My polishing set up is still a little shaky ( due to finances and xmas ) but any jobs that require polishing can be brought back and polished at a later date if the standard i provide is not to my satisfaction.
Also Cooler pipes and intake pipes can now be tackled properly.
any questions can either be directed to Pm or i can be contacted on 0422549050.
Kermit
please be aware that the workshop does have security and i live there too .
Hey Kermit,
have you considered making stainless steel Cold Air Intake boxs? There is not alot available for a BNR32 only really the ARC box. These are like 500 bucks, if i gotta pay that much i'd prefer it to be in polished stainless.
All i reaaly want is a box that fits the front corner of my GTR with a flange on the inside to mount a pod, a flange on the outside to mount the intake pipe and a pipe out the bottom to suck in cold air from outside the engine bay.
cheers
Paul
Now that's just going overboard.. want to put some LED's in there too?:/
I'd be happy with a shield but I think my setup would result in a reasonably odd shape. I may need a bit of pipe to push the pod further from the AFM or I would need a shield shaped thus "<". Having a lid on top is not essential. If you would like a guinea pig.. :laugh:
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
