OK
I have a mate going to the USA in a few weeks, and he has a spare 32kg of luggage he can bring back...
there is a L28et AFM, ECU, DIzzy, Loom and 'boost sensor' etc on ebay.us
im wondering will this stuff fit the l24 without major problems ( i have sourced a turbo, injectors, ex' manifold, and intake), as i can get it here in 2 months if it will fit!
so please help!
  • Replies 201
Yes I have set of DR30 front struts and brakes on hand . I also have the rears ie calipers/discs/hoses/cables that bolt to disk brake style semi trailing arms .
And a late IC FJ20T/loom/AFM/ECU and all the factory optional manifolds (both sides) . No CAS .
Oh and the twin DR30 thermo's as well , and all internals for FJT gearbox . R32 GTR rad .
All sorts of DR engine room bits and pieces looking for another garrage/engine bay to live in .
Ask away .
Cheers A .
Where are you located mate.
I'm in Adelaide and I've probably got a couple things you'd probably be after.
L28 block + flattop pistons (unsure on selling)
2&1/3 inch exhaust to suit mr30.
inlet manifold gear (very similar to 280zx-t stuff)
and other crap.
Send us a PM if you're interested.
DAMN IT!!
I went to get a final roadworthy list last week...
the mechanic reckons it will need $1000 in labour and $1000 in parts.... screw that.
there was a whole lot of sh1t he picked up on.
lower control arms ( arrgh! )
idler arm bushes
oil leack from oil prseeure sensor
diff oil leake (needs new gasketwhere do i get a diff gasket from? )
new tyres all round
brake master cylinder needs replaceing
wiper blades
number plate light not working
exhaust manifold gasket ( where do i get one of these too?)
middle muffler cracked (replace)
rear muffler holes(replace)
front and rear wheel alignment
so it looks like the turbo project will take a break, as my focus will now to get this car on the road...
any help with sourcing control arms, diff gaskets, and exhaust gaskets???
Regards,
Andrew
DAMN IT!!
idler arm bushes
new tyres all round
wiper blades
Regards,
Andrew
Rear wheel alignment ? Hhaha good luck. Fixed rear ends. not much adjustment availble unless custom bushes fitted
DAMN IT!!
lower control arms ( arrgh! ) Bullshit! how many k's has this car done???????
idler arm bushes Same as above
oil leack from oil prseeure sensor this should be easy with some stag jointing compound or plumbers tape
diff oil leake (needs new gasketwhere do i get a diff gasket from? )works 510 or Silastik will do this perfectly
new tyres all round
brake master cylinder needs replaceing I got mine here you can have as I'm doing a 1" conversion to mine
wiper blades $5.00 at Supercheap
number plate light not working globes at Supercheap $2.00 pair
exhaust manifold gasket ( where do i get one of these too?) again supercheap like works510 says
middle muffler cracked (replace) A full system wont cost much more than $300 and you planned this in the turbo conversionrear muffler holes(replace)
front and rear wheel alignment $35 anywhere and front only, if he thinks he can do the rear by adjustment, he's a wanker, coz there is none as stagefumour said
Regards,
Andrew
A wrecker will have fairly good lower control arms and a guy on ebay sells them for $140.00 each and Rare Spares sells the idler arm assembly complete ... new!
Cheers, D
I'd also look to shaving a small fortune off the bill by really hunting around for healthy second-hand tyres. (Try and find a set where 3 are great and 1 is burn-out bald!) Remember you can have different tread/sizes on the front and rear (but not left and right). Check the trading post, the yellow pages or even ebay. Fitting and balancing anywhere should only set you back $40.
Be buggered if I'd blow $450 on a set of mediocre new michelins at Bob Janes!
You can get super-high temperature gasket goo for exhausts from Bursons for about $17.
If you cant get your OP sender to stop leaking I may have healthy spare too. Let me know.
Good luck with it.
Just for anyone interested, I just bought for AU$122.34 including freight a genuine 280ZX Turbo inlet manifold, complete with all attachments plus fuel rails, pressure regulator & injectors. Ex USA and should be here before xmas
is that inlet manifold an ebay item??
i missed out on the gear i wanted last week...
yeah the mechanic was a bit of a wanker, he said he didnt really have time to do it and recommended me to another mate of his, who is a dodgy bugga from a used car yard....
Im not going to get discouraged, this will get done.
Ghostrider, the brake master cylinder you mentioned, how long until it is available? I really want to get the car on the road before christmas if possible.
Im thinking of useing the wheels and tyres from my Pintara ( i got 'TRX' rims and Falkens, and the wheels fit, but i want to put the good tyres on the Skyline rims, dunno if they fit yet...)
Im going to call up a exhaust shop to get a quote today too.
rear end alignment? thats when i thought this guy is a trippa ( i wasnt fully convinced)
There is a red 83 hat at my local wreckers, (along with a L28 carbied C200 or some big arse datsun)
Im going to check out the control arms from that, and the exhaust even (if its roadworthy!) it would be cheaper to get that now, then get a 2.5 system new when i do the turbo setup...
there was a newish looking brake master cylinder in the boot, but it was missing the silver part on the front of it with the lines that come off it.
Ah weel thats all for now...
I'l get an upsate as soon as something else happens
P.S. Ghostrider the mastere cyl, can you get back to me pretty quick on that one?
and coupe72, can you get back to me on the oil sensor (the leak is on the plug side, not the threading...)
A, Will do. Ill have to bolt it into my car and test it first. I'd feel like an ass if I posted you one that was already knackered!
Way off topic here, but who does your freighting D? I've been selling a few bits, like wheels, on ebay and finding someone to transport them has been a bit of a nightmare.
Where are you Andrew? If in Melbourne, I can help you out with a set of either stock 14s or a set of 15s, all with RW tyres.
Im in Ringwood, Eastern suburbs ( just out from Knox City)
Mate that would be such a help!
Can we sort out some pics?
The stock rims that are on right now are in great nick, its just the tyres are small on the front and different treads on the back ( and only one of the back ones are roadworthy...)
Im not sure what sizes the stockies are (i will check when i get home on the weekend)
you can tell the tyres on the front are tiny.... looks gay as
thanks for the help
Edited by MAG86
Mate that would be such a help!)
Glen Waverley
There should be at least 1 pic of the 15s up in the gallery
195/70 from memory
Just had a look at your pic - those look pretty much like the 15s
Edited by blind_elk
I'm taking my Cressida for a run tomorrow night to WSID so I could probably take it off on Thursday and get it posted Friday. Either you get me your address pronto and I'll send it COD or you can send me the postage or whatever. Melbournes not that far away, I have long arms when it comes to that lol
Cheers, D
I went to the wreckers to look at the MR30 they had there, AND THEY CRUSHED IT THE DAY BEFORE....
damnit! i knew i should of got the parts the other weekend!
i was so annoyed...
anyways i looked at the other old dattos and found a C260, man these things looked like the 70's VIP
it has a carbied L26, with GENIE 321 exctractors on it, ( and i didnt have time to see what stamp was on the camshaft...)
i was thinking of bolting the extractors on my L24e MR30 for the time being, (untill the turbo stuff comes along...) they only wanted $40 for them too!
so the question is, What stamp am i looking for on the camshaft, ( is it 'C' or something?)
and will the extractors fit, and will they make any noticeable power difference (i.e. is it worth it?)
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
