  • Replies 83
I will only be able to come at about 1pm. can I still enter and call you (james) to be let in? What's the deal for leaving? Can we leave anytime?
Also if we come from the city there is no toll is there...
thanks
Russ
thanks
Russ
theres always a way around the tolls. depends on which direction u come from. look at www.whereis.com :P
Sorry to burst your bubble guys, but the Show N Shine tomorrow is within a "DRY" zone of the City of Melbourne.
NO alcohol will be permitted.
Its as disappointing for me as it is for you guys, but we must stick to the rules. :)
Official finish is 5.30pm
If you need to leave - just make sure someone is guiding you out (to make sure pedestrians are clear and to remove the bollard). Same with running late - call me (number will be on the bollard) and someone will come to let you in and guide you through.
You need to be 'marshalled' due to safety regulations - again, have to abide by the rules :)
Its as disappointing for me as it is for you guys, but we must stick to the rules. :D
:O I already have the esky in my car and a slab of carrona's packed. :(
It's not a true SAU event without alcohol :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
