Thanks mate - was positive that's the one (with tomei cams, if that makes a difference)...
Need to try JIS, nisswreck & even boostwerx tomorrow morning, as its urgent, lol.
Unless someone has one, in at Prospect until tomorrow late night.
Wanted: Broken Samsung Galaxy s2's and s3's for parts. Paying between $50 and $250 depending on model/damage.
sms me and let me know what you have.
1. screen condition
2. does it turn on
3. has it been reported lost/stolen
Thanks, Sam
0421 460 040
Anyone got any pod filter kit for BNR32? (non foam type) prefer apexi power intakes but will consider other kits. Must include all mounts and be good condition. ph: 0423931815.
Edited by AngelFC
Hi guys
Looking for a r33 intercooler pipe set. Mine has holes in it. The alloy is too crap to fix so i want to get a new set of pipes. Anyone got any for sale in good cond? Or should i just buy new? (im an apprentice so money is a bit tight) maybe even if someone can recommend a place to make them for me?
Pm me if you can help
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
