Seeing as all the sau-vic executives are up in deca, i hereby nominate myself as king of sau-vic!
Probably all the vic-mods are up at deca too so no one can control this thread mwha :dry:
Other executive spots are still avail, take your pick :P
viva le revolution!
https://www.sau.com.au/forums/topic/143766-new-vic-president/
and with the new powers appointed to my self and Tekin, Snowman must give up his r34 gtr to us with duplicate keys created for each sau exec member and any stranger who asks.
I believe the club will grow strongly with this move and provide fun times for all!
edit:
same goes for the both evo's which will be used in various crash experiments for our 'research development' which needs an executive.
Who wants to be in charge of research for crashing evo's :P
time to bring the skylines back into the executive seats! I will not be pushed around by some evo driving hippies with their good fuel consumtion, handling, interior and their engine :P
who's with me!
P.s Dont ban me
Evo's on fuel consumtion? No they don't man.
I nominate myself as a ......whatever that only look after the promote girls!
partick u are a n00ber
lol
u have too much time on your hands.
what you mean? my time has been well put to use. I have restructured the whole sau-vic in an hour :P
Now, each member must repay their membership as the new sau-vic executives need to buy resources for the restructured club..... ARC intercooler would look nice on my car :dry:
oh and booze
I've been here all weekend but simply had too much fun reading your posts.
Why is it everyone always wants to start a mutiny? Aren't we doing enough for you people? :P
Oh, and the guy who looks after the promo girls is Ash. He used to be normal before he got the posting...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
