Im hoping it will chirp second
Anyway the kkr 530 in basically a 480 with a front compressor the same size as a hks 3037…..Kkr 530 with nokia 1000 rrp
Manifold is g-tech 249 + 35 delivery
Dump has a v ban clamp 180rrp
This is the full setup around the 1500 mark
Funnily the kkr turbo has the same thread as a stock vl turbo gear so all my braided lines bolt straight on
199 for the china wastegate
Anyway ill put her on the silvia and see how long she stands up to 14psi and hopfully 280rwkw
https://www.sau.com.au/forums/topic/144472-cheap-rb30-power-up/
  • Replies 98
pictures aren't quite big enough, i can't make anything out :(
while you probably already know that open collector + split pulse housing is a bad idea from a gas flow perspective, it's a really super bad idea if your turbo-manifold gasket is split pulse as well. it can break off in the centre section and go through the turbine, not a good thing. make sure you trim it down (cut the divider out) if this is the case. it won't be optimal, but it'll do the job.
cheers
ok.. one thing i really do not like.. that looks to be a splitpulse T3 exhaust housing on the KKR turbo.. however your manifold isnt splitpulse.. i wouldnt reccomend running that :S its allright with splitpulse manifold with normaly exhaust housing.. but otherway around has always been a big no no in my opion and many others i know of with vast amounts of turbo experience
might loose some grunt i supose... guess the exaust gass will take the easy way out and might make it a tad laggier.. guess ill find out
or i could put a divider in there .. but lets face it that aint going to happen due to lazyiness
oh and those cases are for my lub's and makup
:laugh:
Given the work/trouble you're going to, surely a day's down time + 100 bucks (depending) to put in a divider is worth it?
Despite the opinions about these units - and my own Garrett type leanings - I'm going to be interested to see how it goes.
yeah lovely pj's you sick bastard. intercooler on the bed ehh... I dont even want to know what the "inlet" looks like now.
get cracking big boy. i need a loaner car for the next skid pay day, and you are top of my list. :D
what was the verdict on the manifold? split or not split.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
