R34 GTT vs R33 GTS-4 with turbo
38 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
righto i got a mate thats currently having some sale issues with his NA R33 GTS-4.
so then we got onto the topic about what if we turboed his car? so then yet again a great debate was amungst ourselves.
they claimed that if they turbos the r33 it would completely destroy my r34 GTT
so i guess my question is....because im not so sure about the turnout (i find it hard to believe personally) but what do you guys rkn?
u got a r33 with cooler, exhaust with a turbo form a r33 gtst running stock boost
against
R34 GTT , cooler, exhaust, stock boost
wat would u rkn the results would be?
excluding all factors like weather, day, bloody time of the month shiet.......
pure performance wise straight line who would have it?
Edited by anDru
https://www.sau.com.au/forums/topic/145764-r34-gtt-vs-r33-gts-4-turbo/
I reckon a gts4 with a an rb25 would be faster than your car in any circusmtnace.
r34s are heavy square boxes like r31s. An r33 gtst is siginigicantly lighter than an r33 gts4, but the weight of an r33 gts4 and an r34 gtt are similar.
the awd traction will just make it quicker in the twisties, as well as quicker in a straight line.
your car probably has about 160 rwkw. The r33 will have similar.
so power will be similar, weight similar, it comes down to awd v rwd.
Also, it depends on if you put in a turbo motor, or turbo his. from the sounds of your post, you siad turbo his motor. in that case, it would be a high comp motor, so it'll be quicker and more responsive than yours again.
edited: accidentally put r33 gtt above
Edited by MANWHORE
hrmmmm what you say sounds logical, but putting all that power to all 4 wheels, wouldnt power wise be even less?
close match.........comes down to driver LOL
LOL BAN!!!
Edited by anDru
if hes willing to lauch at 6-7000rpm, if hes a pussy then.......that a diff story. sorry to be a smartass there LOL ive seen sti getting flogged with wrx with just pod and exhaust at the drags.
just comes down on how much bog hes suffers and how much traction u have at the launch otherwise if the condition of these two cars are similar i say gts4 ftw
aaahhh good to get some support here. i was the one who told andru that the our other mates car would be quicker should he turbo it. after all, theres a reason there was never a factory turbo 33 GTS4... it would have been a gt-r for half the price! (yes i know it wouldnt have been exactly but you know what i mean)
If we're talking GTS-4 + t yes it could well take you as the high-comp has funny power delivery and would blast off the line.
But hey it'll probably snap things if he gives it too much, you really need GTR or Stagea driveline parts to give it some stick.
thats exactly what i said. ur still gonna have NA breakes NA this and NA that..and u just slapped on a turbo that i believe would have some troubles running within a NA engine.
personally i think his bound to run into alot of problems and in the end wont even be able to get off the line at 2RPM....
yes it will have NA brakes, but your first question was who would win a straight line drag, bigger brakes dont make you go faster in a straight line, not as much as type R stickers anyway :dry: .
philta, yes i have driven awd cars, not hard out, but you say you need revs to launch good, so wouldnt it make sense that the driver just revs it harder.... alot of ppl are sayin the 4wd will bog down if u dont give it enough, but the question was about all things being equal... things like THE DRIVER.
just car for car which would be faster?
oh and btw, still hasnt been decided if its just turboing his old motor, or to do a complete transplant, but for this comparison, use the latter of the two
edit - actually, go with turboing his old motor, that way no one can use the '33 motor has 20kw less' cause obviously wouldnt use a 34 motor if converting
Edited by VB-
I am going against the grain here.
I honestly beleive the 34 will win easily. I have alot of respect for the NEO6 engine and it is greatly improved over the R33rb25, with more torque and greater power.
Also a GTS4-t will be heavier than a 34GTt; if you want to prove it i can provide the scales.
You mentioned keeping the boost std in both cars, why? Standard boost in a gts4 is 0psi, with NA comp he will be lucky to run 7psi safely, then he still needs some kind of piggy back ecu (or a plug-in). So why not make it a level playing ground. Both cars have ecu's, running as much boost as safely required.
In the twisties the GTS4 will fall off the cliff or into an embankment after 3 bends. Remember it is a heavier car with only 2pots at the front and 1pot at the rears.
My 2c
My 2c
because when u add more mods, its too varied. i can find you a hundred R33 GTSt's with exhaust/cooler/boost the basics, and power levels with vary by 50rwlw or more, by limiting mods you try to keep it more even.
and it was about straight line drag, so handling and braking doesnt come into it.
when we were first arguing, we agreed on 'standard boost', workin on the theory we converted to turbo motor, not just bolted on a turbo. i just said in my earlier post, for this example say we bolted on a turbo so there wasnt anyone saying the NEO has 20kw more... like you just said.
in the end if my mate goes through with this, power at the engine will end up pretty similar, its just a matter of which chassis will use the power more effectively
Edited by VB-
If you install a turbo on a gts4, you will need an aftermarket ecu to run it. Now from my experience; the second biggest noticable modification was installing an aftermarket ecu (the biggest came yrs later when i upgraded the turbo), as this free'ed up ALOT of mid-range torque and power. So you're really not comparing "apples with apples". Keep the same boost, mods, etc, but both cars need a/m ecu's to be on a level feild.
Still have my money on the 34.
You may not have originally discussed "twisties", but the topic has been raised in this thread.
PS: You are talking about installing a std rb25 turbo on the N/A, as this will also affect the outcome.
Also note that power variations also exist between std cars, especially when they get as old as ours, so blaming the variance due to modification is really irrelavent. If it is a good engine and makes good power, great. If it is a weak engine and is tired, too bad :D
Race with what you got, with the same level of modification.
Hope to see the challenge at Calder Park Rwy!!
If you do it on the street i truely hope you get caught.
calders a bit far but any form of race will be held legally of course.
as for comparing the cars, in reality, the GTS4 will probly have a whole host of mods if he goes thru with it, but just for comparisons sake, and make andrew not feel so bad that a 33 will be quicker than his car, we just say there'll only be the basic mods, when in reality.... who'd go to all that effort to have a stockish car
Edited by VB-
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
