Lol ive already seen this :)
a guy in WA has a decepticon badge on his R34.
Also says on the said 'to punish and enslave'
Looks pretty sik IMO.
That's Ryan (NISZILLA). I'll try and find some pics of it. Nice car, and well thought out mods.
those are from a sauwa cruise up north :P was an epic cruise!!! so much fun..cept got a chip in windscreen from it :)
just got plates a week ago :)
waiting to buy some white te37's :D
Edited by Neuroglider
:thumbsup: thanks nick, bad thing with that hot front bar.. is 1. fibreglass 2. got it from JSAI = fibreglass already splitting etc :P bugger.. and i hardly drive the thing!! *sigh* i will see you at the nsw 'sns' im guessing, along with terry, matt, shanil etc
Lovin that front bar dori :P
@Steve
Fronts: 18x8.5 +30 235/40
Rears: 18x9.5 +20 245/40
As for scrubbing on the rears at that height, it only happened very rarely. There was about 8mm clearance between the tyre and the fender.
cool, fitment is pretty
i run
18x8 +24 235/40
18x9 +23 265/35
been scared to lower the rear down too much because of the bigger tyres. think i need to put on some 235 or 245s on the back to get it sitting nicely
Took some pics with mates 370Z at Vic Imports Cruise (car was sooooooooo filthy as you can see it wasnt a great day lol) displaying some CF bits :(. its nothing big but the little things does make a difference
Cheers mate, just cant wait to put this in there
I hope you have Twin Turbos to go with that RB26...
What front spoiler is that? It looks really good without being ridiculous looking.
If you are referring to the front bar then I think it is just the stock one.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
