Ztune was my preferred option but I got turned off by:
A. Genuine part is ridicilously overpriced
B. Hard to find (genuine)
C. If i was to get a copy I would need bonnet pins to stop the bloody thing flying off at high speeds and collecting my windscreen along the way.. This would take away from the clean look and further more add to point "D"
D. Adds at least 50 points to the "Pull me over and defect me" factor :glare: . In its own is a huge defect due to being a CF bonnet
In saying this I will probably still go down the path and get one lol :P
I have mine painted both top and bottom...makes it far less obvious for defects, and so glad they make the smooth look bonnet pins now aswell....far cleaner look
A V-Spec II Bonnet is also Carbon Fibre.
I am aware - however if i purchase a vs2 bonnet it will be genuine and being an OEM Nissan item you would sincerely put some trust in knowing it wont fly off at higher speeds unlike a Ztune carbon fiber replica bonnet made by an external manufacturer where often or not looks > functionality and reinforcement and quiet frankly I dont trust the latch with these at high speeds.
Ive decided to go ztune w/ bonnet pins though despite my initial discomfort in using pins lol come at me boys in blue
Edited by nomnomv8
Yeah, I was more so referring to point 'D.' you made in you post before.
But yes, safety and functionality is a high priority :)
Yo Phill, was trying to figure out what rims they were at WTAC?? Shed some light?
Rims are Do-Luck Double six in 18 x 10.5 +20 all round with 235 front and 245 rear.
Looks very nice :yes:
Woo nismo front bar.
Yeah Nismo S Tune :)
more pics Phil!!!
More pics as requested, sorry for the late reply..
Edited by phillb
Looks insane!
Thats not a Bayside blue is it? looks much richer or maybe its the camera or maybe its just my eyes? Whatever it is its come out great.
Being a little particular, but i reckon get the amber rear fog light cover to complete it
Still tossing up on if i should colour code my skirts and rear pods like this and the others above or leave them black, im liking both ways
Beautiful car. Just curious as to what guard work had to be done to fit 10.5 +20 all round??
Is the clearance any different between a 4 door and a 2 door?
Looks insane!
thanks mate! the paint is House of Color Candy Cobalt Blue. the candy type of paint makes this rich effect. in real the color is much impressive, i plan to make hd video to show the color effect.
i thought of amber light, costs 50 usd brand new, but not sure if to install in, anyway this is GTT, not a GTR, i'm not into 100% copying GTR look, just made the body wider by GTR fenders...
the carbon made skirts and rear pods look nice and match the carbon bonnet, but if it's black better to paint them in car color, imo
Edited by 427
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
