Ah right. Quite lucky then! I've seen quite a few companies in Aus have the Z-Tune style one available to buy (not to mention the endless supply of cheap copies) but not this one. I do really like that one though. Can you still use the standard strut brace with that bonnet or have you got an aftermarket one?
All fits with the standard gear. luckily.
My old bonnet which is a knock off job sort of, of this one is at BodyForm MotorSports for sale. Difference is its fibreglass, still painted white and has bonnet pins in it as it didn't fit as perfectly as this one.
Here are some pics of the other bonnet:
hey all 34 drivers i was wondering what spring rates your all using, im in the market for some new coilovers and want to go a fair bit softer then what i have now
F6 R8, was thinking even as low as 5kg all round because the roads are sheit where i live and was wondering if thats going to be too soft. im thinking going BC fully adjustable coilovers for their price and info or help would be much appreciated
cheers
New one looks much more flush. Especially without the bonnet pins. And even better with the fact everything fits! Thanks mate.
What wheels?
Looks like work meisters/ssr professors but the spokes are thinner?
Liking it!
they're ROTA D2-EX
http://www.rotawheels.com.au/wheels/rota-d2-ex
rotas newest rip offs
definitely not real meisters
Highly doubt they'd be forged. Price tag looks to be around $1000 mark.
Might look into this when tax money comes back lol, can't justify to fork out ~$3k for real ones, being a uni student and all :(
edit: Not a R34 but damn they got my vote!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
