  • Replies 392
Well the splits wont but my new turbo will... :rofl::)
:huh::laugh::P:)
you serious?! thats not fair!!! the conditions of the show down clearly states it has to be a rb20det with a stock turbo!! :mad:
i might come along and spectate, i had mine dynoed a few months ago.
I got 160rwkw @ 10psi
ah cool nice bench mark - ill see how i go...
Edited by ZENNON
;):no::(:O
you serious?! thats not fair!!! the conditions of the show down clearly states it has to be a rb20det with a stock turbo!! :)
yeah i was quite suprise....but it is set a 14-15psi...but it wont hold it for some reason. so would of had about 180 or so if it held it....stupid turbo.
hey there should be in i think just have to get the money together but shouldnt be a problem will be interesting to see wat my 33 gts25t can do cos i havent had it long and it hasnt been on the dyno yet, not expecting too much though as it only has a 3 inch cat back exhaust im pretty sure and turbo tech boost controller on 9.5.
Officially count me out :) I've got a full-day lecture at Uni on the Saturday.
I understand Dan, your pulling out cause of the taunts you recieved by other R34 owners and you dont want to put them to shame... I support your choice and will make room for you when you decide to return...
Yeah Matt your in, you have until the 2nd week of Feb to transfer the money anyway so plenty of time to save the money...
Dont forget its not to late to join the qld club also, this way you will recieve the run at the discounted price and a free snag and drink...
So if you join just before this event you will save at least $15 already, so really membership is like $40 if you think about it, not to mention the discounted events up and coming this year... Really my membership is free when I think about the use I have had for mine...
Col you wouldnt happen to be a salesperson would you?
Yes
have you started your mods yet col ??
Yes, they are allmost finished... I just have cooler piping and the tune to go...
The engine is all back together and the dump pipes were finished yesterday, for an excelent price i might add...
Haha you mean you heard a sigh of relief from the other boys, they fear the pwning of my car :)
Look fingers crossed they give me credit for the course and I don't have to go, but 1 Saturday compared to 13 x 170kms worth of trips over 3 months = a saving of over $350 in fuel :D
That'd cover the rest of some new injectors and would see me in the +250rwkw zone :)
HackerX
Your added to the list...
Yeah join for sure before the 2nd week of Feb... As i said eariler its your first chance at a discount and some freebies, so its well worth it...
Also have a read of this thread > http://www.skylinesaustralia.com/forums/in...howtopic=104137
This will assist in your membership, if you have any further questions please feel free to PM 'SMR33' as she will take good care of you...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
