  • Replies 56
iv got the same problem at high revs in my s2 33 going from 3rd to 4th aswell, and once it has done it going from 4th to 5th, i went to a couple of places and they sed it might be cheaper to get a new box :P they say it a lot of work replacing the syncros ;) i brought up that changing the oil to redline will stop it but they sed it will just hide the noise and will result in the gearbox needing a rebuild down the track
i have yet to go to a few other places and suss it out :huh:
I had a similar problem in my 33. Was crunching slightly going into second and third... i put in Redline Shockproof (yeah the blue stuff... red bottle if i remember correctly) and after a few days the crunching completely went away. It is heaps better to get into any gear and certainly justifies the cost (i think it was like $125 for the bottle or something :laugh:)
Just my 2c :)
very common problem for skylines to crunch going into high gears at high RPM. My R33 has very low k's and even with good synthetic Motul gear oil it isn't perfect into 5th at big speeds (and the Motul was still a big improvement over the original gear oil!).
Ill try the redline blue stuff and get back to you all.By the way i just had a new clutch fitted,when the box came out they found the clutch pivot pin at the bottom.It had sheered in half.Took forever to find another one.Now the crunching is worse into 5th anything over 2000rpm an it will crunch.So now im driving like a grandma until i can figure something out.
well one would ask where you would be redlining 4th anyway.. im going to assume a track or dragstrip..
Redline shockproof oil is not recommended for gearboxes with syncros... even redline state this.
Castrol VMX80 is a better alternative.. all you're really doing is masking a problem that ultimately needs to be fixed
Just a quick question. I dont have anything wrong with my GB. But i got some VMX80 cause i am planing to change the oil. Will this make the GB worse if there is nothing wrong with it in the first place?
at high speeds I sometimes crunch going into 4th, but only really at 150 or more, so it doesnt really phase me as a rarley see that sort of speed.
If im paitent on the gear change it go's in fine anyway. I just dont think the synchros can keep up at thoes speeds.
No, VMX80 has been tried and recommended by many people on here.
My S2 had a genuine 34,000km on it when I bought it and I noticed a marked IMPROVEMENT when I dumped the factory oil and filled it up with Motul Gear 300. You will probably notice a difference in shifting quality when you put fresh oil in, too.
Yes it is very annoying, my car crunches in forth when entered with high rpm from either second or third, anything over about 4k and crrruuuunnnncchhhh, even when i wait a while with the clutch pedal depressed and still crunch.
I put the redline oil in and found it makes gear changes generally smoother put only really masks the problem as it definately did not go away. Anyone know how much new synchro's would be to put in? or how much a rebuild is?
the RB25DET boxes have dual synchros 1st-3rd and single synchro 4th-5th, 4th seems to be very common synchro to let go in these boxes.
Cost of rebuilding varies greatly depending on what is needed. If you are replacing all bearings and couple of synchros expect to pay just under 1K or up to 1.5K for all new synchros. (plus R&R of box itself)
  • 3 weeks later...
The 33 box is common for this, the fourth gear synchro gets a little tired and eventually wears the input shaft. If you are hard enough on them the selector fork will break in half. I rebuilt one with new bearings, synchros and 3rd/4th selector fork and it lasted just over 12 months, in the end it broke another selector because the worn input shaft wouldnt allow a smooth meshing.
^ how much did it cost?
if you have f**ked synchros and are prepared to have it rebuilt.
as if you would choose the same damn gearbox!
i dont know exactly what a good gear box ugrade would be for the 33 but its not practical to put the same gear box back in and rebuild it... obviously the 33 synchros cant handle the shifts
my 33 got this problem from fast 1st - 2nd shifting. now it crunches slightly only when i shift as quick as i can.
but that was my old car.. i have a new 1 now doesnt crunch but it hasnt been given anything yet.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
