just ran my GT2860's at 1.75 bar, seat of the pants feeling is they run out of puff about 1.4-1.5 bar were as my HKS gt2530's were still happy. I did also change my manifold but I don't think it is related. At this stage my hks 2530's had a more on/off power with more efficiency up top and the garretts are more of a street turbo with good response but not the same top end that I like to run. I'll get a dyno graph done as I'm only guessing atm. I'm aiming for 500rwhp if the fall behind by over 70hp I'll upgrade.
  • Replies 157
Posted Images
The latest:
I datalogged 1.4bar and 1.7bar and found my AFR dropping into 10.8:1, I leaned it off a little to 11.3 and did some more driving.....well alittle more. It felt pretty sweet until I got into third and broke my 6th gearbox, lol. These turbo's my have promise yet.......
anyone got an OS Giken 1-3rd heical gearbox or gearset forsale???
http://www.turbobygarrett.com/turbobygarre...60-10comp_e.gif
according to the map the GT2860R-5 will run up to 30psi however run out of puff at 1.6bar(26psi)
so what was the max power output mate
Yeah well be careful not to get the Nissan ones.. $17 per stud... do the maths on that...! :)
holy shit thats bullshit.i should have keep the ones out of stock turbos.. :)
also question for anyone who knows,with the oil return pipes they have to be modifyed yes???
:) Now you should go in a car with 2860R's and tell us what you think...
Yes I changed from T517Z's to 2860R's..
Yes I have MUCH more response..
The T517Z's were good for top end, more suited to drag racing, will make good peak power...
No I wouldn't change them for anything.....
No I wouldn't buy HKS items, the price of the Garretts are too good refuse...
Nengun are selling bolt on GT-SS s with bolts gaskets basically the lot for $400 more than 2860R's but you will have to find all the bits yourself if you buy the garrett turbos. You say the T517Z's were good for top end well they must be the 10.0 cm2 ones and not the 8.0 cm2 ones which are very responsive.
regards micov
did ya read the whole thread. i think youll find some good results with 2860r. and you say find all the stuff ya self.like what??? few gaskets studs maybe some copper washes. not that much..
regards micov
Ummm no dude, they were definetly the 8cm version and they were definetly not as responsive... :)
And I would put that extra 400 bucks towards some decent dump pipes....
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
